Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Dodge Ram Decals
View Poll Results: What is better?
Supercharger 48 52.75%
Procharger 16 17.58%
Twin Turbo 27 29.67%
Voters: 91. You may not vote on this poll
Old 06-25-2013, 08:44 PM
JCummings's Avatar
JCummings JCummings is offline
Vehicle: 2012 1500
Color: Mineral Gray
Rep:26
JCummings is on a distinguished road
muddy,
where have you read that? this is the first time I have heard it...
Mods: Lowered and Blown.
Old 06-25-2013, 09:11 PM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
x2
There's a long trail of roasted tranny's, even with minor bolt on NA Rams,
but I've never read about a 4G Eagle Hemi engine failure on ANY of the Ram Performance boards I frequent. Boosted or not.
Links or it didn't happen
MGH has run his Twin Turbo AWD 2010 Ram HARD since 2011,
Broke a handful of 545RFE's before he figured out how to build a bullet proof one
by trial and error that's been good for over a year now on two of his Turbo builds on 5.7L 4G's
Both 5.7L Rams pushing over 500HP/500TQ (at the wheels) on all stock internals.
You can safely boost to 6-7 psi without worry as long as your a/f doesn't run lean.
The guys pushing 8-9 lbs of boost are using alcohol injection (Water/Meth) kits if they're smart
to keep things cooler/safer while adding more fuel to avoid leaning out the mix at higher RPM.
http://www.alcoholinjectionsystems.com/index.html
Benefits Of Water Methanol Injection:
  • Lower air charge temperatures by 50-250+ degrees
  • Reduces cylinder temperatures up to 300+ degrees
  • Increase your 87-93 pump gas by 8-20+ points
  • Increase horsepower safely by 10-15%
  • Allows you to safely run more boost and timing
  • Cools and protects the tops of your pistons and upper ring
  • Longer more stable combustion expansion and progression
  • Removes carbon build up from combustion chambers, pistons and valves
  • Reduces & helps eliminate engine damaging detonation & pre-ignition
  • No need for expensive racing fuel or additives
Old 06-27-2013, 10:55 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
I wouldn't mind reading about the blown motors too...links?
Old 07-01-2013, 08:09 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Anything that boost the power is good but you always have to consider what it is you are trying to achieve before slapping $$$ on the counter. I looked at many options to boost my 2007 and cost effective thoughts kept stopping me from putting another 7 to 8K in my truck. I like it just like it is was my final call but then I was offered a golden opportunity to buy my 2012 F150 EcoBoost with Twin Turbos that I have been using for work this past year and of course I bought it. I get anywhere from 21 to 25 MPG depending on how much I play while driving. If there were a twin turbo available to put on the Hemi then it is a no brainer where I would spend my money.
Old 07-01-2013, 12:58 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
21-25 MPG and still having fun? Damn, that was a great call.....something Id hate to say.....but damn
sales@revelperformance.com
Old 07-01-2013, 01:20 PM
Graygoose's Avatar
Graygoose Graygoose is offline
Vehicle: 2015 Ram Bighorn
Trim Level: Bighorn
Rep:110
Graygoose will become famous soon enoughGraygoose will become famous soon enough
Spoke to Edelbrock while on the Power Tour, the E Force Supercharger will be out in about 90-120 days
2015 Crew Cab Bighorn
Old 07-01-2013, 01:23 PM
Revel Performance
Rep:1804
How accurate is this info as Im interested to find more details on this
Not doubting your....just excited for another option of SC
Old 07-01-2013, 02:35 PM
Graygoose's Avatar
Trim Level: Bighorn
Rep:110
Just talled to National Sales Manager a week ago, he said fitment is done, working on calibration at this time. Theirs has been plug and play on the Chevy/Ford, and they like others have an option to purchase motor/tranny extended warranty to cover theirs, like that idea.
Old 07-01-2013, 03:37 PM
Revel Performance
Rep:1804
Sweet!
I'll look into this as well.
Extended warranty is something nice.
I'll want to know their fine print which I'll find out too when I call
Old 07-01-2013, 03:54 PM
Graygoose's Avatar
Trim Level: Bighorn
Rep:110
Sweet!
Cool, also talked to Magnuson on PT, they also have the ability to give you a warranty on tranny/motor.
