View Poll Results: What is better?
Supercharger 48 52.75%
Procharger 16 17.58%
Twin Turbo 27 29.67%
Voters: 91. You may not vote on this poll
Old 08-05-2013, 12:16 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Originally Posted by jerseymike View Post
Looks nasty!! Now all you need is LSD x 2 so you can smoke all 4 tires.
You can't put a locker or limited slip in the front diff of a 1500 Ram 4x4,
Only solid front axle HD Ram differentials are strong enough to take the torque.
...and why on earth would I want to "smoke" my tires?
Old 08-05-2013, 05:13 PM
Wow.....great install
When is the trans arriving?
Old 08-05-2013, 05:54 PM
Rep:554
My track Bud and I ran to the border to pick up a pair of them two weeks ago,
along with a our 3K stall ATS Triple Lok TC's in Montana
(saved a crap load of shipping/brokerage fees)
De-greased and stripped them, then painted them last week...
Ready to install next weekend.
Both of us have Ripped Rams, 2010 1500 4x4's
(one RCSB, one QCSB) ...not the Cummins, that's just his hauler
after paint ... Silver (BRH) and Copper(MGRAM)
Still dont have our Deep Mag HyTech pans yet...
Old 08-05-2013, 06:54 PM
Man, I am officially jealous
Cant wait to see this all come together.
I will PM you when ready to get contacts off you
Old 08-05-2013, 10:41 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Has anybody ever looked into adding the Kenne Bell unit from the Challenger? I know the motors are the same and the program is different but has anybody ever looked into it?
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 08-06-2013, 09:42 AM
Rep:554
It's ALIVE!!! Ripp 0-60 Run on my Trinity
Along with my Edge 3K stall she shoots out of the hole like a rocket,
Burned off a whole tank yesterday cruising around, still gets 20 mpg highway
Dont ask about City cuz I'm a lead foot.
On the way home I thought I'd do a quick 0-60 test on my Trinity,
Keep in mind, Heat soaked temps after running all afternoon in 75º-80º heat
coolant temp and oil temp 180º, intake air about 15º over ambient (95ºF)
Heavy 305/50R20 Terra Grapplers on stock 20' (about 95lbs per corner)
3.55 stock gears, RCSB 4x4 transfercase in 4-Auto (AWD) so full traction
Just a chirp from the tires and the front grabs and goes at full throttle launch.
Stock shift points 5600rpm
My first pull was 4.41 seconds,
launched Hard and even chirped into 2nd in AWD!
unfortunately I cleared it before I could snap a pic.
Made another run so I could grab a quick pic to post.
Once I mount my 4 little 28" Drag Radials get in track trim and raise my shift points
she should run close to high 3's, Can't wait to see some track slips.
New MGH Trans could be going in this weekend
New fuel pump on order (Aeromatic Stealth 340)
my CMR Dyno tuner wont run it until my pump gets upgraded,
He says the stocker is maxed out at that HP when she hits about 5600 rpm.
I tried some roll on 4th gear pulls on the highway and its pulling like a Freight Train on the top end too.
Old 08-06-2013, 02:48 PM
Wow man!
What do you think you are pushing at the wheels both HP and TQ wise?
Old 08-06-2013, 03:21 PM
Rep:554
Wow man!
My bud did his several few months ago, same truck 10' 4x4 Sport (QC though), similar mods... (but stock TC and TB....mine are both upgrade)
Even though HP was still climbing at 489 we shut her down as the stock fuel pump couldn't keep up after 5500 rpm and it started leaning out.
With a bigger fuel pump, and water/meth kit...over 500 easily!
He's also swapping out his JBA shorties for ARH Long Tubes
Old 08-06-2013, 04:39 PM
Oh right!
I recall seeing that and recall you mentioning that too.
That is crazy!
Im sure you are grinning as you romp on that pedal now
Old 04-02-2014, 10:20 PM
Rep:554
This thread has been dead for quite a while...and so has my Ram lol.
(Killed TWO transmissions already, going onto #3 build next)
Quick update on my build, since some people think a 545RFE will take the stress
Last Fall, about mid September I smoked the OD frictions on my Stock Trans! (2 months after supercharger install)
sure was FUN while it lasted though
Last run at the track had the trans slipping at every shift (left lane)
Swapped my L&M Customs built transmission right away,
and ATS Triple Lok 3000 Stall
But Smoked the OD frictions on that one within just TWO Weeks
...I did not get my transmission tuning in time, thought it was okay to run,
but I guess without the line pressure boosted to hold the frictions they burned up.
It's been parked for the Winter ever since.
I Now have my trans tune, and the snow is almost gone
Also have a new modified Ripp tune (was too rich before)
Thanks to Mike (MGH) working with Josh at HHP.
Mike sent me all new OD Frictions for his Trans, no charge
and a full set of over drive, under drive, 2C Frictions and Steels
to rebuild my original stock trans from one of his cores.
Stock Over Drive, Under Drive clutch packs:
Stock 2C (intermediate 2nd frictions)
Replacement L&M OD (12 Double Sided Alto Red Eagle Frictions)
My bud Brad (MGRAM) and I will crack the stocker open this weekend,
R&R the frictions on that one as a trial run, since it's already on the bench.
If all goes well, the following weekend we'll drop the L&M trans out and do the same.
Bench Break Down vid of a 545RFE...
While the transmission is out I'm going to toss my stock cats and JBA Shorty Headers.
Cuz these arrive by FedEx Tomorrow afternoon,
...thanks to Matt at Moe's Performance
$719 JBA Silver Ceramic Coated Long Tubes, 1-7/8" Primaries, No Cat's
