Trail grapplers on fuel octane - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-07-2013, 10:32 PM
M.c.laren M.c.laren is offline
Vehicle: 2012 ram
Color: Mg
M.c.laren is on a distinguished road
Default Trail grapplers on fuel octane
I've been reading and searching for about a week and a half but can't find a definite answer. I found a deal on some 295/60r20 nitto trail grapplers on some fuel octane rims. My truck is a 2012 1500 sport crew cab. So far I've heard some people say the tires will fit no problem on the factory chrome clad rims (20x9) and others say they will rub and you need spacers. The other thing is that the fuel octane rims are used and the guy doesn't know the offset or anything but says they were on a 2007 ram 1500. Lastly, the rim/tire setup is 2 hours away and I'd only like to make the trip if I have a good idea that they will fit. Any help would be soooo much appreciated.
Thanks,
Blake
Old 04-07-2013, 11:22 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Thanks,
Blake
If you look on the backside of the rim the offset should be stamped on it here is an example hope this helps
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 04-07-2013, 11:32 PM
Vehicle: 2012 ram
Color: Mg
Thanks, what specs would the rim need to have to fit without the tires rubbing?
Old 04-07-2013, 11:39 PM
Cat Daddy's Avatar
Cat Daddy Cat Daddy is offline
Vehicle: 2012 Ram 1500 4X4
Rep:68
Cat Daddy will become famous soon enough
I am pretty sure the stock off set is -19.... I put a set of 295 on my stock rim and they would rub when truck was on the lift ....they hit the tie rod or some shit...1/4" spacer will fix it ...so if don't want to run a spacer then you need -13 or so...great looking tire I dropped down to the 275-65-20 ..really thinking going 18" can go 315 and the are like an 11.50 so a little under the fender with out flares
20X9 Black XD Hoss with painted caps 275x65x20 NittosTerras,Bilsteins 5100's @ 2.1, .75" in rear,laminx tinted head lights,tinted tail lights & 3rd brake light, S&B,Fastman 84 TB,18' Magnaflow,T1000-hemifever,cabin filter,RECON led cab lights,custom dynamic 60" light bar,tow hooks,debadged ,6" shorty ,painted grill and front and rear emblem , AMP power step ,F1 Bacflip bed cover ,Mopar bed rug kit
Old 04-07-2013, 11:46 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
OP your factory wheel are a +19mm, if you do not want to run a spacer you are going to want to go with a +12mm, maybe even a little bit less say a +10mm.
Hope this helps
Jeremiah
Old 04-08-2013, 02:01 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Trim Level: Express RC
Color: Black Express Package
Rep:67
My wheels are +12 you want at least that or less with a 295 to be sure of no rub. I run a 285/60 and have plenty of room for a wider tire. Although my 305/55' s rubbed the sway bar at lock.
Old 04-08-2013, 10:44 AM
Cat Daddy's Avatar
Rep:68
thanks for getting the correct offset out there ....
