Old 04-13-2013, 03:44 PM
Rob 93ZR1 Rob 93ZR1 is offline
Rep:13
Rob 93ZR1 is on a distinguished road
Default 17" Wheel Questions 2013
Looking to replace the stock 20" wheels with aftermarket 17" rims. I would like to better understand offset and backspacing, but need a starting point. If the OEM wheels are 17x7 with a +1 offset, does that mean the backspace is 4.5"?
Mickey Thompson classic 17X9 5X5.5 4 1/2backspace -12 mm offset.
Or the Pro Comp series 99 wheels.17x8, 5 on 5.5 Bolt Pattern
Backspace = 4.5 in
is the offset +.5"?
I am going to keep the stock tire size 265 70 17 but would like the tires to move out from stock about 1/2" max.
Please help get me on track. Thanks in advance!
Old 04-13-2013, 08:52 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
http://www.galantvr4.org/docs/backspacing.htm
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
For the 9" wide wheel you will want a +12mm offset to get your 1/2" that your are looking for (extending out).
Old 04-13-2013, 09:18 PM
melvinsacromentoe melvinsacromentoe is offline
Vehicle: 2002
Color: light blue
melvinsacromentoe is on a distinguished road
I also have 20 factory wheels, i want to replace with smaller after market wheels but i heard that you cannot change the wheel size is this true?
Old 04-14-2013, 08:21 AM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
That's not correct. What you're missing is that wheel widths are measured bead to bead but backspace is measured from the lip. The lip is normally 1/2" past the bead so that needs to be added in. Add 0.5" to your 4.5" and you'll come up with the correct 5" BS for that wheel.
Here's another calculator that I like for comparing tire/wheel installations. http://www.rimsntires.com/specs.jsp
Old 04-14-2013, 08:24 AM
Color: Mineral Gray
Rep:17
That's not true. You can change from 20's to 17's. These trucks are made to work with 17 inch wheels and many come standard with 17's. Going smaller than that you could run into the issue of your brakes not fitting in.
Old 04-14-2013, 02:26 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
I just posed a thread in the Lifting section where I replaced my stock 20's with a set of 17" aftermarket wheels with a 0 degree offset if you're curious... however I went up to 35" tires... Here's the Link to my thread.
http://www.ramforumz.com/showthread.php?t=139401
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
