Old 04-06-2013, 02:28 AM
TriSum's Avatar
TriSum TriSum is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:47
TriSum is on a distinguished road
Default Rear Belltech shocks...
Has anyone noticed that the metal sleeve inside the rear shock bushings is slightly larger than the factory bolt that is supposed to be re-used.
I was installing the rear suspension earlier and tightened the rear shocks by hand and noticed the shock would "wiggle" up and down. Obviously if you tighten the bolt enough to squeeze the bracket against the sleeve it won't move, but it doesn't seem right.
Has anyone gotten larger diameter bolts for the rear shocks?
David
2012 R/T
ARH Longtubes, Diablo Trinity, Flowmaster, Belltech 2"/4" Lowering Kit, Spohn Track Bar, Hellwig Sway Bars, QA1 Double Adj Shocks, Bak Flip "VP" Tonneau Cover, Oil Catch Can, Rear Air Bags
Old 04-06-2013, 11:55 AM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I have experienced this almost every time when installing lift/lowering kits, Where a bushing and bolt doesn't match up. It's very annoying, and I don't understand why it's so hard to get right. Always end up searching for different bolts/bushings to correct the problem.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
