Old 04-06-2013, 04:52 AM
aepowell's Avatar
aepowell aepowell is offline
Vehicle: 2013 Dodge Ram SLT LONESTAR
Trim Level: 1500 SLT LONESTAR QC
Rep:99
aepowell will become famous soon enough
Default Uconect phonebook question.
Does anyone know how to delete the phone book numbers in the 8.4? For some reason all my numbers are in there twice. I woul like to erase them an do a fresh install.
Aepowell Sherman,TX.
Old 04-06-2013, 07:04 AM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Would this work for you ?
Delete All Entries in the UConnect™ Phonebook
• Press the ’Phone’ button to begin.
• After the “Ready” prompt and the following beep, say “Phonebook Erase All”.
• The UConnect™ system will ask you to verify that you wish to delete all the entries
from the phonebook.
• After confirmation, the phonebook entries will be deleted
Regards
Old 04-06-2013, 07:08 AM
arietem's Avatar
Rep:368
Hi, you can also try to do a full factory reset of the Uconnect system .. that of course would reset EVERYTHING ...
Regards
Old 04-06-2013, 07:18 AM
aepowell's Avatar
Rep:99
from the phonebook.
I'll try this. Thanks
Old 04-06-2013, 07:47 AM
arietem's Avatar
Rep:368
You may also try deleting your phone .. then re-PAIRing it .. this should wipe out the phonebook entries that are loaded in the system.
J
Regards
Old 04-06-2013, 09:09 AM
Qball57 Qball57 is offline
Trim Level: 1500 Sport
Qball57 is on a distinguished road
I will have to try that myself. All my contacts numbers show up twice. One has a mobile phone icon in front of it and the second has a dot in front of it. Then whenever I call someone I have to say a 1 or 2 before it will finally dial.
Old 04-06-2013, 09:30 AM
arietem's Avatar
Rep:368
If deleting the phone and repairing is not too much of an issue, it may be a good way to get a clean start and a new phone book loaded into the system.
J
Regards
Old 04-06-2013, 06:09 PM
aepowell's Avatar
Rep:99
I deleted my phone and it cleared the phone book also. I set it all back up and it put the numbers in 2 times each again. I'm baffled.
Old 04-06-2013, 09:45 PM
arietem's Avatar
Rep:368
Hi, try this, see if this helps:
http://www.ramforumz.com/showpost.ph...65&postcount=5
Well, I figured it out. Looking through my phone to see if there is any possible way that the contacts were duplicated, I stumbled accross somthing called iphone link in my contacts. It looks like when I upgrade my phone that itunes copied all my contacts from the old SIM card to the new one, but it created a duplicate file. When I look at the contacts in my phone there is only one of each, but when I go into the contact and scroll all the way to the bottom there were two "iPhone links", each of which was a full copy of the contact. I had to manually delete each duplicate, but at least it's done now.
Regards
