Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 04-06-2013, 04:23 PM
Nymisus Nymisus is offline
Vehicle: 2012 Dodge Ram 1500
Nymisus is on a distinguished road
Default First oil change...
So I've decided to do my own oil changes on my 2012 Ram, used to do them all the time on my jeep, and must say whoever thought of putting the oil filter where it is should be fired. Any tips on how not to get oil all over the crossmember when changing it? I just put a rag there, but that was after I had already taken the sucker out...and there was definately more oil in there than I remember my other vehicles having after draining it.
Old 04-06-2013, 04:56 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
It's a PITA, but I switched to the Fram XG 16 filter and use Penzoil Platinum 5W20 and change at 10,000 miles. I used to change at 5,000 mile intervals. Especially like the hot oil dripping off my elbow while changing. Never thought I'd endorse a Fram filter, but the XG is a 10,000 mi rated filter and the oil does stay cleaner. You might buy a cheap rain coat to wear for changing oil, my wife is not impressed when I come in drenched in used oil.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-06-2013, 05:21 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Pull the bolt on your pan and empty your oil, take an ICE pic or whatever pointy metal screw driver you got and make 2 holes in the bottom of the filter, in opposite locations, i.e. one at the lowest part of the bottom of the Filter and one at the top area of the bottom of the filter. (hope that makes sense), the oil will now empty itself from the filter and run down the plastic tray just below. Once empty, loosen the filter, place a plastic bag over the filter and unscrew and remove, clean the area of the filter up and the plastic tray, also make sure your rubber seal has come off with your filter. put a little oil on the new filter rubber gasket and install the new filter. Fill your oil to capacity. Done
Old 04-06-2013, 05:40 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
Asur, you make it sound so simple...
Old 04-06-2013, 05:49 PM
12RCRam's Avatar
12RCRam 12RCRam is offline
12RCRam is on a distinguished road
I took a one foot by one foot piece of cardboard and bent it in the middle, I hold it under the drain and it guides the oil to the drain pan without making a mess.
Old 04-06-2013, 06:27 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Very good ideas why didn't I think of this ? I will remember this next time I do an oil change!
Thanks
Jeremiah
Discount Auto Performance
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
That's because Al's a genius!!
Old 04-06-2013, 07:01 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
A Kroger 1/2 gallon ice cream bucket also works great. It will sit on the RP as filter drains in it, you never touch the hot oil.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 04-07-2013, 10:37 AM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
Remote oil filter mod..
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 04-07-2013, 12:50 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
Do an oil change on a Jeep liberty or Dodge Nitro and you will forget all about firing that RAM oil filter guy...
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
