Old 04-07-2013, 08:53 PM
deboer's Avatar
deboer deboer is offline
Vehicle: 2004 Dodge 2500
deboer is on a distinguished road
how much play in the sleeves?
rating on the ball its self?
personally i'd probably add 1 maybe 2 bolts to the drop.
Old 04-07-2013, 09:24 PM
OxyG3nE's Avatar
OxyG3nE OxyG3nE is offline
Vehicle: 2012 Dodge Ram SLT
Color: Dark Blue
OxyG3nE is on a distinguished road
in the drop there is no play in the sleeve and the ball is 6000lbs rating but my trailer is doing max 5k .. and the drop have 2 bolt (i didnt put in the pic ) so i should put more?
Old 04-07-2013, 09:32 PM
deboer's Avatar
for the pulling I do i'd put a 3rd on in for sure, but I pull from 7500-10000+ off of mine. so if there isn't much play and your only pulling 5000 and the ball is 6000 you should be fine
Old 04-07-2013, 09:37 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Well....you always got the safety chains, lol , actually with that grade of bolts, you shouldn't be too bad off.
Old 04-07-2013, 09:38 PM
deboer's Avatar
valid point! you'll be fine
Old 04-07-2013, 09:42 PM
OxyG3nE's Avatar
Color: Dark Blue
hahaha i just want to make sure since the trailer have all my racing equipement... it would be desastrous if something happened !!
What take all the force on a hitch like that? from accelerating and brake (the lower bar ) or from up and down? )
Old 04-07-2013, 10:36 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
You may be OK. The ball is only rated 6k, and you say you tow 5k.
Well, you probably weakened the ball/shank some when you welded it on, as it was designed and rated for being bolted on, not welded.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 04-07-2013, 10:49 PM
OxyG3nE's Avatar
Color: Dark Blue
ok you guys scared me .. i just ordered a RAPID HITCH ADJUSTABLE ALUMINUM BALLMOUNT 10" DROP .. rated 10k ...
Old 04-08-2013, 12:06 AM
deboer's Avatar
True i forgot about that. Yes your ball probably lost some strength by being welded. But i'd still feel safe with only 5k behind on a 6k ball
Old 04-08-2013, 12:34 AM
Rep:2642
As long as the bolts & nuts are at least Grade 8, you should not have any issues
i wouldn't trust Grade 5 & Grade 2 or 3 is a joke
Grade 8 bolts have 6 radial lines on top of the bolt head
