Broke Temp gauge that swings all the way right - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 04-06-2013, 11:59 PM
SScott's Avatar
SScott SScott is offline
Vehicle: 2001 Ram 2500 4X4
Rep:19
SScott is on a distinguished road
Default Broke Temp gauge that swings all the way right
Hello and thanks in advance. I have a 2001 2500 4x4 with a 360 and auto. The temp gauge pegs out seconds after the key is on. I put in a new sender and a new gauge and checked the connections. I tried to short the two wires on the sender but that did not change anything.
Old 04-23-2013, 05:43 PM
SScott's Avatar
Rep:19
A little background info if it helps: I have only had the truck about a month. The guy I got it from just put the engine, transmission and rear diff. in. I do not know the level of skill he has or if everything was put back the right way. My ABS, Check Engine, Brake and Air Bag light stays on and the check gages from the temp gauge when it swings over. The truck runs good but the cruise does not work and the 4x4 does not lock in. I have never owned a dodge so I don't know if a light is supposed to come on but I spun the tires on gravel after putting it in 4 low and only the rear grabbed. This is about all I can think of. Thanks!
Old 05-28-2013, 07:54 PM
SScott's Avatar
Rep:19
If anyone is wondering...I got an ECM thinking that could be it and it did not help so I started tracing all the wires...it ended up being the plug on the sensor was pulled out of the socket just enough to not connect, I redid the connection and it works fine now.
Old 05-29-2013, 02:23 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Scott, I apologize that no one, including myself, responded to your problem.
I didn't notice the thread, however...I do feel obligated to giving you rep points for posting the solution to your problem.
temp gauge
