What PSI to run in airlift 1000s? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-07-2013, 11:46 AM
maximus007's Avatar
maximus007 maximus007 is offline
Vehicle: 2010 Ram Crew Cab
Color: Light graystone metallic
Rep:12
maximus007 is on a distinguished road
Default What PSI to run in airlift 1000s?
Just installed my airlift 1000s last night. Now just wondering what psi to set at? What is everyone running for psi when your not towing? Thanks in advance
Bilsteins set at 2.8, rcx1.25 bodylift,fuel krank wheels with 35in toyo at 2s, tinted windows, K&N drop in,14" Magnaflow muffler, Diablo Trinity 1000 hemifever tuned, airlift 1000s, 2500 fender flares color matched, spray in bed liner, moroso catch can, 180 t-stat
Old 04-07-2013, 12:12 PM
pjs1660's Avatar
pjs1660 pjs1660 is offline
Vehicle: 2011 ram 1500 outdoorsman
Trim Level: slt outdoorsman
Color: green
Rep:137
pjs1660 will become famous soon enoughpjs1660 will become famous soon enough
according to instructions is says 5 psi minimum
Old 04-07-2013, 10:39 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
I have mine at 20 and still hit the stops. So far not super impressed honestly.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 04-08-2013, 12:09 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
How much weight are you putting on the truck to make it do that?
Old 04-08-2013, 08:24 AM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2017 Jeep Grand Cherokee
Trim Level: Laredo 75th Anny
Color: Billet Metallic
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I have mine at 14-15lbs all the time. Love them. Better cornering and the ride is just a tad bit stiffer.
No More RAM
Old 04-08-2013, 11:55 AM
Outdoorsman2012 Outdoorsman2012 is offline
Vehicle: 2012 Ram Outdoorsman
Trim Level: Oudoorsman
Rep:39
Outdoorsman2012 is on a distinguished road
Granted mine were at 35psi but I had 4 guys in my truck and 1500lbs of wood and still had 3 inches until bump stops. Something doesn't seem right
Old 04-09-2013, 07:27 PM
blackedout12's Avatar
blackedout12 blackedout12 is offline
Vehicle: 2012 Dodge Ram
Rep:19
blackedout12 is on a distinguished road
Maximus007
I just received mine today. How long did it take you to install and how did u run the air supply?
McG 2/4, Smoked Tails/3rd, Tonneau Pro Tri-Fold, Debadged, Paint Matched Interior, FlowMaster Exhaust, LED Brake Light Bar, K/N Drop-In
Mods from Bully Performance:
AirLift 1000's, Jet T-Stat 180*, Vararram-T1000-Future Mods--Ordered
Old 04-09-2013, 11:30 PM
Rep:39
Dedicate 2-3 hours. Its really easy but running lines can take a while. I think it took just under two hours for me. I ran the airline right out of the top of the coil and then into the from. The frame has holes periodically which work great. I drive a lot off road and did t want lines to snag or rub on anything. I installed the fill points on the metal between the tailgate and number that's recessed like two inches. There's two holes punched there so no cutting. I didn't want to cut holes in gas cap or plastic bumper in case I took them off. Then no one could know they were there. Installing fill point makes it much easier if you have stardard fill and gauge I have extended ones so this wasn't an issue. I wrote up a small install on here and included pictures for reference
Old 04-11-2013, 09:47 PM
Ramfd's Avatar
Ramfd Ramfd is offline
Vehicle: 2009 ram 1500 QC 2wd
Trim Level: Big horn
Color: Brilliant black pearl
Rep:150
greg what kit did you buy? I am running the Belltech kit and the airlift 1000 for a 2009 dodge durango. I run the bags at 8-10psi all the time and never hit the bump stops.
I had 2 yards of wet sand in it with the bags a 35psi and it sagged all the way to the bump stops, But i think i exceeded the capacity of the truck and the air bags.
Old 04-13-2013, 11:54 AM
Rep:19
I just finished installing the kit I got from DAP. Everything was there and came in on Tuesday and I ordered Sun. So if your looking at getting a kit see DAP.
The kit took about 2hrs to install. I ran my lines down the frame and my air port is on the receiver hitch on the right side fit was perfect with the pre-drilled holes from factory. I am running about 10psi right now but I'm not too stoked about the install. Now I have a big gap between wheels/fender that cleared up once the 2/4 was installed. I'm sure it may settle a little and will close the gap. If not I may remove due to the look I was going for. I really don't like the rear higher than the front. I like the slight bulldog stance where the front is a hair taller and squatting some in the rear. I will post a pic later of the fill port.
