Old 04-07-2013, 12:32 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
Default First Major Repair = First Nightmare
It's times like this that I'm so glad I work at a Chrysler Dealership...
So all last week my '12 R/T (which isn't even a year old yet) was up on my hoist at work with no transmission in it. A little back-story, really ever since I bought this truck I noticed that it had a noticeable downshift shudder on the 4-3 downshift, I never really thought much of it because it IS a Chrysler transmission and I always figured that it would go away as the truck broke in. Fast forward to 8000 miles, its still there.
So last Monday I told my service manager that I was gonna write up my truck for a trans problem and probably get the STAR help center involved. (God forbid I just start working on my truck, because I'm a Tech so its obviously warranty fraud whenever I want to fix my truck) I wanted to talk to the STAR center anyway since my truck had to codes, tsb's, flashes, ect... By the way, if you don't know, the STAR center is just a huge group of people that are there for dealership mechanics when we have problems we just can't figure out, they're there to provide some help, even though most of the time they are usless.
Anyway after looking at this and looking at that on the scan tool while test driving my STAR agent finally told me to go ahead and tear down the 65rfe trans, which is what I was going to do from day one. I pull it out and totally tear it down and I found that one of the clutch packs (2c) was bad, the clutch material started flaking off and the steels were all burnt. Also the LR clutchs were all discolored. And I found fine metal material all through the trans from the failed clutches.
Here's were things get ridiculousness I order up all the clutches and steels in the trans, apply pistons, a solenoid pack, seals, basically an entire overhaul package. I try to order a new torque converter because of the metal contamination I found and the parts guy says that torque converter is only avaliable with a whole new trans assembly, its not serviced by itself. So at that point I have to get authorization from Chrysler to put a whole new trans assembly in my tuck, which they deny right away. So I call up the Chrysler powertrain people and fight with them for over an hour. NO ONE THERE EVEN KNOWS THAT THE RAM R/T COMES WITH A DIFFERENT TORQUE CONVERTER!!! So finally they give me a torque converter part number and tell me to use that, I check it with parts and what a surprise its a normal RAM torque converter.
I fought with Chrysler for 3 full days about this torque converter, and I fought with my service manager that kept telling me to use the regular torque converter. Finally on the third day I reached someone pretty high up at MOPAR and after doing some research he found a torque converter that is only used with RAM's that have a 4.10 axle (rpo code DMF) Which the R/T is the only current RAM offered with a 4.10 axle. I order that, rebuild my trans and BOOM everything is good.
Sorry for the long as hell post but I think all R/T owners should know that Chrysler and Chrysler dealers have no idea what a RAM R/T is and will just put regular RAM parts in your truck.
So to avoid headaches here is the R/T torque converter part number:
RL143188AA
Write that down and keep it somewhere, Ill take some pics of the burnt clutches when I go back to work on Monday.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 04-07-2013, 02:17 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Glad you finely got it worked out bro...
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-07-2013, 03:11 PM
I push the skinny pedal
Rep:3277
This is always a problem when I walk into a dealership, I know more about the parts in the vehicle than the service counter does. Unless you want a very specific part and have a VIN to back it up they just seem lost. They can't even look up parts by the trim line, which is a little annoying. I understand that there's a lot of cross-over, but some things are trim specific.
Glad you got it sorted out.
Kurtis
Old 04-07-2013, 05:07 PM
Rep:73
Yea even working as a tech at the dealer its always a nightmare trying to work with the parts guys. They're just off in their own little world, they don't care when you get the part or if its damaged, or if its wrong, they only care that it shows up as sold on their books.
Check em' out:
Old 04-07-2013, 05:37 PM
Rep:2657
There used to be a Parts guy at the dealership that i use, he would really research parts for me, if he was in doubt, he would get on the phone & call someone he knew.
One day i walked in there & i was told that he no longer worked there.
It was just after that dealership changed over from having a Cashier that took care of all of the money transactions for the Service & Parts Dept. to a system where everyone had to do their own transactions, it slowed down the whole process & customer wait times drastically. 2 of the 7 Service Advisers walked out too
Old 04-07-2013, 07:48 PM
ejb426 ejb426 is offline
Vehicle: 2013 Ram 1500 CC 5' 7" bed
Color: Copperhead Pearl
Rep:20
ejb426 is on a distinguished road
Sounds like you're dealing with the wrong parts guys. I am definitely not like that. I wish I could work for a Chrysler dealership, I am stuck at F@rd
Old 04-07-2013, 08:12 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Glad you got it sorted out. Gotta say, my dealer is awesome. Because I drag race, they even give me 20% discount. My first Ram, Toyotas before. Toyota dealer sucked azz.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-09-2013, 03:09 PM
rodmillen's Avatar
rodmillen rodmillen is offline
Vehicle: 2013 Ram 1500 Sport
rodmillen is on a distinguished road
This is why I stopped workign for dealerships. Had this been someones truck that didn't work at that dealership, they would have a normal ram torque converter in their truck when they paid to have the R/T truck with the torque converter. It just blew me away when the service manager would tell me things like that and I'm like, they will have a total different experience in the sport truck they bought. Im glad things worked out for you man
Old 04-09-2013, 03:11 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
service managers are a bunch of tool bags that dont know shit about cars
One tried to blame my hood led's for burning out my pcm
Old 04-09-2013, 04:07 PM
Unfairkickazz93's Avatar
Unfairkickazz93 Unfairkickazz93 is offline
Vehicle: 2012 Dodge Ram 1500 RCSB 4X4
Rep:173
Unfairkickazz93 has a spectacular aura aboutUnfairkickazz93 has a spectacular aura about
Well thats good that it was sorted out!
Supposedly they have different trannys too.
Does anyone know the difference between the RT trans and a stock one?
MODS- QTP Exhaust Cutout, ARH Long-tube Headers, HornBlasters Train Horn, HemiFever Tuned, Linex bedliner, Painted mirrors and door handles, 14" magnaflow muffler, Cabin air filter, BakFlip G2 tonneau cover, Black 17" Sport Edition TK5 Wheels, K&N CAI, BT Catch can, 85mm Throttle body, Upper glovebox Mod, Recon Black Projector headlights, Retroshops- Tinted LED Tails including 3rd brake.
