First Major Repair = First Nightmare - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram Special Edition Models > Dodge Ram R/T
Old 04-09-2013, 05:46 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Glad that in the end it worked out for you, but you shouldn't have to go through all those problems......
Old 04-11-2013, 07:29 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
Originally Posted by Unfairkickazz93 View Post
Well thats good that it was sorted out!
Supposedly they have different trannys too.
Does anyone know the difference between the RT trans and a stock one?
The trans is the same as a regular ram, 2009-2011 RAM R/T's have the 545RFE and 2012+ RAM R/T's have the 65RFE, which is the same exact thing as the 545RFE but the 65RFE has an alternate second gear it can choose for better acceleration when passing. The only difference between a regular RAM trans and a RAM R/T trans is the torque converter. I've read somewhere that the valve bodys in an R/T are slightly different for harder shifting but after having mine apart I saw no difference at all. Plus the valve body's in an RFE trans have pretty much nothing to do with shifting, thats all done by the solenoid pack.
Another fun fact...the "special" R/T torque converter is just matched to the 4.10 rear axle. A 2600 stall torque converter with a 4.10 axle is the equivalent to a 2100 stall torque converter with a 3.55 axle (not sure if I have the stall speeds correct but you get the picture.) That "special" torque converter is also used in some new grand cherokees and durangos since they also use the 65RFE. I was kind of disappointed to find that out...but whatever.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
