Old 04-07-2013, 02:08 PM
srt4bigturbo srt4bigturbo is offline
Vehicle: 2003 dodge ram
Trim Level: Slt
Color: blue
srt4bigturbo is on a distinguished road
Default Cab swap please help!
I just put a 2004 1500 hemi cab on my 2003 ram hemi 1500 and everything works other than it wont turn over and the gauges don't move? I used all the outer wires from the 2003 and the cab wires from the 2004 could that be the problem ? am I going to have to use all the 2003 wires ?
I know I need to use the 2003 key and switch but it should still turn over.
Old 04-07-2013, 03:38 PM
Stampede4.7 Stampede4.7 is offline
Stampede4.7 is on a distinguished road
That is probably your issue. The wiring harnesses are not plug and play, you will probably have to move pins to different locations. What pcm did you use? Are you doing a Hemi swap, what is your main goal with swapping the 03, 04 and the 05 harness?
Stampede.
Old 04-07-2013, 05:25 PM
Trim Level: Slt
Color: blue
Stampede.
I bought the truck cheap with a smashed cab... I guess Im going to swap all the cab wires over
Old 04-07-2013, 08:10 PM
Trim Level: Slt
Color: blue
So I just got done swapping all the cab wires everything works turns over but wont start ? the fuels pump is kicking on.. There is also a red light on the dash that has lighting bolt?
Old 04-08-2013, 01:01 AM
Trim Level: Slt
Color: blue
anyone????????????????????????
Old 04-08-2013, 01:17 AM
Rep:2657
just guessing
you may need to use the 2004 computer & sensors
Old 04-09-2013, 12:51 AM
Trim Level: Slt
Color: blue
just guessing
I used everything 03 and it ran before so it should run now? it turns over just has no fire
