temp blend switch - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 04-07-2013, 05:19 PM
Matt1924's Avatar
Matt1924 Matt1924 is offline
Vehicle: 1999 Dodge Ram
Trim Level: SLT Lariat
Color: Red/Silver
Matt1924 is on a distinguished road
Default temp blend switch
Hi there. Had an issue a while back with a/c staying on hot all the time. Replaced the blend door actuator underneath the plenum on passenger side and now I can switch between hot and cold, but not anywhere in between. Basically, once I reach the mid way point on the dial, it goes all the way hot or all the way cold. Any ideas? Thanks in advance.
Old 06-05-2013, 09:51 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
Can you explain more about what you mean by "replaced blend door actuator"? If its the typical symptoms, the actuator does not need replacing, only the plastic bushing/hinge.
Sorry just want to get a better idea before suggesting anything else.
it could be that your rheostat (dial) is shot or needs cleaning.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 06-15-2013, 07:50 PM
Matt1924's Avatar
Color: Red/Silver
Thanks for replying. The actuator bushing was broken, and the motor was fried as well. I replaced both of them, which allowed me to alternate between hot and cold air. Only now there is no "in-between"- only all the way hot, or all the way cold.
a/c and heat, blend door, temp control
