Old 04-07-2013, 07:13 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
Default Biggest tire size
I know this has been beat up already but i cant find a lot of info on it. I have an 08 Big horn 4x4 quad cab. I need new tires and wondering whats the biggest i can go. I have no leveling kit or lift. Stock 20" rims. Ive been looking at 305/55/20, 295/60/20. I really like the Nitto Terra grapplers and Dune grapplers. I need a good AT tire so other ideas would be great. Thanks
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 04-07-2013, 07:19 PM
shanerocks shanerocks is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Quad Cab
Rep:21
shanerocks is on a distinguished road
I believe with both of those tires you will need at least a 2" level. Im sure someone else will chime in. There are a couple vendors on here that can get you a level kit. If you still like the rake just add a rear spacer to get it back. If your looking at a good AT tire I would stay away from the Dunes. Toyo makes 2 great ATs (Open Country AT/and the more aggressive ATII)Good luck.
Shane
( . Y . )
Old 04-07-2013, 07:24 PM
IrishRedneck86 IrishRedneck86 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT 4x4
Color: Detonator Yellow
IrishRedneck86 is on a distinguished road
Well with a completely stock setup no level or any lift you can run a 33" diameter tire as thats the stock height for the Rams you just have to watch the width so you dont rub with normal turns and especially at full lock.
Old 04-07-2013, 09:57 PM
Color: Cool Vanilla
Rep:63
Ive been looking at the HBS leveling kits. Will a 305/60/20 fit with the 2.5" kit. I dont want to buy wheel spacers.
Old 04-07-2013, 10:33 PM
Trim Level: SLT 4x4
with the kit it should fit the height as its a 34" tall tire but it may rub when turning as its a 12" wide tire if your running the stock 20's with no spacer due to the deep positive offset. I could be wrong so anyone feel free to correct my statement about the rub if I am.
Old 04-09-2013, 07:36 AM
Color: Cool Vanilla
Rep:63
I keep reading that some people have no problem with rubbing but then others do. Ill buy a leveling kit if i need to. I just hate to buy a 305/55/20 and it dont fit.
Old 04-09-2013, 08:05 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Height isn't really the big factor here. You can easily run a 34" tire on the factory suspension. You don't really "need" a level until you start getting into the 35" tires. The problem is the width. You are correct about some folks seeming to have issues and some not, however, the general consensus for the 06-08 trucks with OEM 20" rims is that 285 is the widest you can fit without spacers. There is a good thread on here from a member with an 07 that mounted 295/60/20 Trail Grapps and he had to run 1/4" spacers. The good news is that a 1/4" is all you need to run even 305's.
A 1/4" spacer isn't big enough to really cause any issues. Many folks have good luck with off the shelf cheapo spacers but Motorsports Technologies makes the best custom made hubcentric spacers that money can buy. There was a member on here with a set of them for sale recently if they are still available. Hope this helps.
Old 04-09-2013, 10:11 AM
Judd McPherson Judd McPherson is offline
Vehicle: 2013 Ram Sport
Rep:192
Judd McPherson has a spectacular aura aboutJudd McPherson has a spectacular aura about
I have the pair for sale mentioned above. I bought them and then ended up not needing them for my build out. They are $125.10 on Motorsport Tech website and it usually takes a couple of weeks until they get enough orders to do a large run of them. I will sell for $100 shipped to your door. They are definitely worth it over cheap auto parts store ones, as they are made specifically for the Ram OEM wheels and hubs so you never have to worry about tire balance issues. Mine are new in the box and have never been mounted.
