Trams question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 04-07-2013, 08:03 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:224
bstc00 has a spectacular aura aboutbstc00 has a spectacular aura aboutbstc00 has a spectacular aura about
Default Trams question
I have a SC and before I get it installed I wanted to see what trans I would Need to get to support the extra HP. I is my truck every day to tow anything from 3500lb to 7500 lb.
Thanks
Old 04-07-2013, 08:19 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
If you mean transfer case, our stock case is pretty bullet proof. I use my Ram to yard out logs, pull the hell out of it in 4X4. I eventually had to replace the chain because it stretched. If your talking transmission, I hear the guys at www.sharadon.com are the best. Most importantly, you get it properly tuned for the boost. I'd get a Diablo tuner and get it tuned so you don't get detonation.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-07-2013, 09:47 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Is SC for superchip's or supercharger???
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-08-2013, 01:19 PM
bstc00's Avatar
Color: Inferno Red
Rep:224
Sorry about the first post. It has been fixed. SC - Supercharger.
Old 04-08-2013, 01:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
what supercharger? If you are adding ~100hp or less the stock trans should be ok. Pending how you drive of course...
Sean
Old 04-08-2013, 07:33 PM
bstc00's Avatar
Color: Inferno Red
Rep:224
I have the RIPP Supercharger. I know ripp said they put over 22k on there truck with oem trans, but I would like to be safe.
Old 04-08-2013, 08:30 PM
snrusnak's Avatar
Rep:1388
yeah I'm sure there are options out there but I've read a lot of horror stories with trans swaps. Some people spend nearly $10k on transmissions and it never runs right.
Sean
Old 04-08-2013, 08:39 PM
MeanMango2010's Avatar
MeanMango2010 MeanMango2010 is offline
Vehicle: 2010 Ram 1500
Color: Mango Tango
Rep:59
MeanMango2010 will become famous soon enough
You will need to upgrade your transmission with the RIPP. Mine only lasted EXACTLY 9,000 miles before it was toast. That was with just the supercharger and Mufflex. I don't know about Sharadon but they seem to be comparable to what MGH from here on the forum is building for me right now. CHVYKLR has a trans built by him and loves it. I pick mine up tomorrow and install it Wednesday. He is providing a trans tune to put in through my Diablo which will compensate for the extra pressures and such required.
2006 Ram 2500 MegaCab Cummins - White Shadow
2010 Ram 1500 Mango Tango - Punkin XpressSOLD
Old 04-08-2013, 10:28 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
MGH's trans builds are pretty solid. no complaints here. two guys with some know-how can have it swapped in a few hours.
Old 04-09-2013, 12:57 AM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
What happen to make your trans go out? Where you hot rodding it a lot? And did you ever get a custom tune for your setup or just used the base tune? Sorry to ask so many questions your the only person with real experience with the ripped kit I can ask. I'm really wanting to get this setup in September just looking for good info thanks.
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
