84 royal se with sloppy steering - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 02-13-2013, 12:03 AM
Kyleandchristy Kyleandchristy is offline
Vehicle: 1984 Dodge Ram Royal SE
Trim Level: Unsure
Color: Grey with a touch of Brown
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
Kyleandchristy is on a distinguished road
Default 84 royal se with sloppy steering
This is my first post so let me know if I left anything out. I purchased a 1984 Dodge Royal SE about a week ago. When I drove it I noticed that it has left to right play in the steering wheel and you can turn the steering shaft by hand about 1/4 of a turn in both directions. Where would be the best places to start looking for this problem?
It also has about a 6 inch lift on Gumbo Monster Mudders 17/40-15LT.
Old 02-13-2013, 08:57 PM
Mojack's Avatar
Mojack Mojack is offline
Vehicle: 2012 Ram 1500 ST
Color: Deep Cherry Red
Rep:65
Mojack will become famous soon enough
There is a coupler, that is almost always worn out, between the steering box and the shaft going up to the column. If it has side play or rotational play it needs to be rebuilt (which rarely fixes it completely) or get an after market shaft with a small universal joint built in like a Borgeson shaft. They're about $200.
2012 Ram 1500, 1979 Trailduster,
1972 Duster 340, 1965 Valiant 340
Old 02-13-2013, 09:12 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The coupler comes apart by removing the roll pin and then you can check the bushings. FYI they're the same bushings as a manual shift bushing.
Old 02-14-2013, 12:45 AM
Trim Level: Unsure
Thank y'all much and I will take it apart tomorrow.
Old 02-14-2013, 01:56 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Then look further down at tie rods, center link, idler arm, possibly even the steering gear itself. They all are easy enough to see slack in by simply watching them move while someone turns the steering wheel back-and-forth (with vehicle weight on the tires).
Old 04-07-2013, 07:21 AM
The War Wagon's Avatar
The War Wagon The War Wagon is offline
Vehicle: 1992 Dodge Ramcharger
Trim Level: LE 150
Color: Black & Grey
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Rep:67
The War Wagon will become famous soon enough
Send a message via Yahoo to The War Wagon
Lightbulb
BORGESON is your friend, with a 6" lift. I have a 4 1/2" lift on my '92 RC, and I'm going with the HD Borgeson steering shaft AND the Borgeson steering gearbox. $587 & change before shipping from JEGS, but money WELL spent with a lifted Gen.1!!!
'92 Dodge Ramcharger... a work in progress...
'07 Jeep Commander... tow vehicle... :-p
