Old 04-08-2013, 09:28 AM
Mitch24 Mitch24 is offline
Vehicle: 2005 Dodge Ram
Mitch24 is on a distinguished road
Question Need help: got k&n air intake and now engine dies
I have a 2005 Dodge Ram 1500 with the 4.7L engine. I just put in a new K&N air intake on it two days ago, and it seems to be idleing low and has died 3 or 4 times when i was stopped or had it in park. Today is the first day I have driven it a considerable amount since putting on the air intake. My dad and i put it on, and did everything as directed. What could be the problem? The only non-stock parts it has is k&n air intake and Flowmaster exhaust.
Old 04-08-2013, 10:24 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Hopefully your MAF(Mass Air Flow) Sensor wasn't damaged during your swap. Did you unhook your negative battery lead to reset ECM/ECU while installing your CAI? Hopefully it's just a loose clamp or something. Otherwise, MAF's can get expensive. Good luck bud and let us know what ya find.
Old 04-08-2013, 10:28 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Uhm...he doesn't have a MAF sensor I'm almost positive. Just an air temp sensor
i suggest just double checking wire connections that you may have bumped
Old 04-08-2013, 11:12 AM
Yeah, I will check all of my wires. I had to drill into the air intake hose and installed the air temp sensor right, but I will look and make sure no wires are loose.
Old 04-08-2013, 11:14 AM
And yes I did unhook the negative battery cable
Old 04-09-2013, 09:02 AM
Do you know how to set the idle higher on that model of truck?
Old 04-09-2013, 10:28 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
You shold not have to adjust idle in any way coming from a stock intake to an aftermarket one. We dont have a MAF but we do have a MAP sensor. Make sure you have all of your connections, wires and hoses, connected and tight and they are not cracked. Worst comes to worst, IF you did damage that in istallation, they dont cost that much to replace....i seen $40ish + on the internet.
When i hear of this problem i instantly think vacuum leak somewhere. So double check everything. Also make sure anything you may have modified on this intake is sealed. If you allow extra air to enter at the after the MAP sensor, It will run rough and die.
Old 04-09-2013, 10:58 AM
Where's the map sensor located at and what's it stand for?
Old 04-09-2013, 02:20 PM
tjbiker031's Avatar
Rep:118
manifold absolute pressure sensor (MAP sensor). It basically measures the air pressure coming into the engine so the computer can regulate proper running conditions. With out it, your engine basically will not run right.
Upload a pic so i can see what you did
Old 04-09-2013, 02:22 PM
Rep:1900
Side note, tjbiker031...
you seem very knowledgeable and helpful to some of these guys on here. Wish you'd come around more, we could use more guys like you.
4.7l engine, air intake, dodge ram 1500, engine dies
