Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 04-08-2013, 07:20 PM
WJSimacek WJSimacek is offline
Vehicle: 2000 Dodge Ram 1500
WJSimacek is on a distinguished road
Default How to plug master cylinder while making repairs
Hi,
I'm starting an ambition job, at least for my skill level, of replacing a broken steel 3/16" brake line located in the frame right around the gas tank.
I have one very basic newby type question, as I work on the brake lines, how do i plug them so the Master Cylinder resevoir doesn't drain completely out, which I'm told if it does requires bench bleeding?
I've already got a set of flare wrenches, a Double Flaring Tool Set, a roll of 3/16" line and a kit of connectors. ...and some good goggles to prevent any splattering into my eyes.
Anything else I need?
Wish me luck!
Wayne
Old 04-26-2013, 06:06 PM
Xman Xman is offline
Vehicle: 2012 Dodge Ram
Trim Level: Outdoorsman
Color: Gray
Xman is on a distinguished road
In this situation, I would use a syringe to suck the fluid out the reservoir. If you were going to reuse it make sure you store it in a bottle that has no water in it. I would most likely replace the fluid with a synthetic brake fluid.
Old 04-29-2013, 10:24 PM
YO208's Avatar
YO208 YO208 is offline
Vehicle: 2010 Dodge Ram 1500 Hemi 4x4
Color: Blue
YO208 is on a distinguished road
what you should do is wedge the brake pedal down with a pry bar. that will prevent the fluid from dripping out of the line during repair.
