2011 HID light question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-09-2013, 05:14 PM
kenny4128 kenny4128 is offline
Vehicle: 2011 Ram 1500
kenny4128 is on a distinguished road
Default 2011 HID light question
Hello All, I have been all over the internet searching for the right 55w HID kit for my ram truck. I know I need the H11 kit, but my biggest isue is I have herd many issues with our trucks not accepting most run of the mill HID kits without flickering issues, or tire pressure indicators going off. So my question is, what kits are you guys using? Any issues? I have been looking at the **************** 55w 5000k kit, any thoughts? I know its a lot of questions but I love my truck and want it to look good and everything to work perfect. Cheers!
Old 04-11-2013, 02:39 PM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:38
BC18471 is on a distinguished road
You can take you chances with an ebay special, but those are where you will tend to see issues. The RS kits are a bit more, but...you get what you pay for. Plus, they have very good customer service. You should do some research in the Lighting forum. There is lots of good information there.
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 04-11-2013, 06:19 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1230
I got my kits from XenonDepot.com, and they work great. my TPMS indicator comes on for 5 seconds when I first turn on the headlights, then it goes away and everything is flawless.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 04-12-2013, 09:25 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
DON'T forget to finish the instalation by doing a proper light output adjustment. You'll see better and you will not blind oncoming drivers as bad with your illegal lights.
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 04-12-2013, 11:45 PM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
What makes his lights illegal?
Btw I would pass on the Retro kits. Most people I know aren't happy with them. What's unfortunate is that when someone post a negative thread on them it gets deleted, sad how these forums work....Also JJ who does the retro'd lights (retroshop) also changed his hid supplier. Can't imagine why...
[CENTER][SIGPIC][/SIGPIC]
Old 04-13-2013, 04:58 PM
eight-bit eight-bit is offline
Color: Green
Rep:107
eight-bit will become famous soon enougheight-bit will become famous soon enough
In most states running HID lights in a non-HID housing is illegal. The light dispersion is all wrong and it's a hazard to other drivers. Retrofitted projector is the way to do it... Makes sure the light goes where it's supposed to, doesn't blind other drivers.
Old 04-17-2013, 01:59 PM
blackpearldodge's Avatar
blackpearldodge blackpearldodge is offline
Vehicle: 2015 Crew Cab 1500 Sport 4x4
Rep:19
blackpearldodge is on a distinguished road
The same holds true up here in Canada.
Once you have Black you'll never go back! Hmmmm.....well... now that isn't quite true. I went back to WHITE!
Sport Performance Hood, OEM Mud Flaps, Factory Spray-in Bed Liner, CREE MK-R LED Fog Lights
Old 04-21-2013, 01:01 PM
s9779's Avatar
s9779 s9779 is offline
Vehicle: 2011 ram
Trim Level: sport
Color: gray
s9779 is on a distinguished road
In every state in the county there is a law on the books requiring all automotive lighting to be dot approved when activated on public rounds. As of this time and most likely for any foreseeable future the Dot will not certify any retro kits for street use. Even if they did certify the kits they still require a max color temp of 4100k. All factory lights use bulbs with this template regardless of how the light looks when it's bent through a projector. In my state you will fail required state inspection with a retrofit kit. Hope this info helps.
2011 RAM 1500 crew cab
Old 05-02-2013, 08:02 PM
Color: Green
Rep:107
Your state is my state. If only inspection shops bothered to actually do their jobs, me and you would be blinded by far less ricer civics :/
