Old 04-09-2013, 06:55 PM
fdc1970 fdc1970 is offline
Vehicle: 2005 Dodge Ram Daytona 4x4
Trim Level: Daytona
Color: GoMango
fdc1970 is on a distinguished road
Default 05 Ram Daytona 4x4 suspension Need Help!
Greetings, I have a '05 Ram Daytona 4x4 reg cab all stock with 32,000 miles on it. (14" Magnaflow only mod) I plan on keeping the factory 20" wheels and tires on this. I want to keep this as a street truck so I want to try to make it handle on curvy/bumpy back roads best as possible since I tend to drive fast at times since I live in the middle of nowhere with the roads to myself. I like the tight firm "truck feel" so not looking for a soft ride just something better than factory ride that's starting to feel a bit sloppy to me.
First thing I want to raise the front about 2" to help level it but they don't sell adjustable 5100 bilsteins for 05 Dodge Ram 4x4? so that stopped me dead in my tracks to collect parts.
What is the best way to raise the front about 2"? (I read somewhere crank torsion bars?) Once the front is raised I want new shocks front and rear installed and not sure if the Bilstein's 4600 Front: 24-069281/Rear:24-025508 is a good choice all around for a better than OEM ride but I would think they are. I would appreciate anyone with knowledge for this truck to help me be able to get the parts I need. Thanks
Old 04-09-2013, 07:13 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:441
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
When my 05 was new, I had the dealer add a leaf to the rear and crank up the torsion bars to almost level , about 2 inches. The installed Rancho 9000 shocks all around. Eventually I cranked them to maximum firmness and love the control. Only thing that I could think to improve, might be a rear sway bar. I tow a 10,000 lb fifth wheel with her, no problem. The extra leaf makes it handle loads better, a lot better. Ride is on par with a 2500 or even a 3500.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 230,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-10-2013, 05:34 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
Smile
Crank the torsion bars and call it a day.
Jack the front end up until the tires are off the ground, crank them, then lower the truck down and take it for a spin. Then re measure the height and adjust accordingly.
Cranking the bars will stiffen the front end up and make the ride firmer like you are looking for.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 04-10-2013, 05:47 PM
Trim Level: Daytona
Color: GoMango
Thanks for the info. I guess when this goes to a shop I'll have them raise the front up a bit with cranking the torsion bars. I don't have to buy anything for that right? I seen a torsion bar key online is that just a tool that is for home mechanic? This truck is not going to see off-road or ever haul anything that's why I call it my "car". I do drive it in rain and also snow sometimes. The rancho from what I read seems more like a hauling/towing ride. Are the 4600 Bilsteins all around a good choice they're $59. ea anybody running them? Improved handling for street use compared to OEM? I would get a rear sway bar as well but I don't get much online time to read best choices. I need to get parts collected for the shop most likely a Dodge dealer just tell them what to do, have an alignment and leave. I'm just hoping whatever I get I'll leave happy.
Old 04-12-2013, 12:34 AM
Trim Level: Daytona
Color: GoMango
Ordered the 4 bilsteins so between that and a front up 1" and front alignment I think I'm good for awhile or this is going as a trade-in for something new.
