Old 04-10-2013, 06:45 AM
CmRam's Avatar
CmRam CmRam is offline
Rep:52
CmRam will become famous soon enough
Smile
Alright then, I will go with the 4.10s in the near future! Thanks everybody for their input I appreciate it.
Old 04-10-2013, 07:12 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Hey CmRam. Have you considered dropping down to a 30-31" diameter tire instead? Especially if you are lowering your Ram instead of lifting. I would bet you could improve your times a bit better. With the 33" tires, the 3.92's turn them quicker than our 3.55's. It's just the opposite end of regearing. The reason for 3.92's or bigger is because of lifts and running 35's or bigger plus the added weight of the tire and wheel combo. If you go the other direction, say lighter wheel and tire diameter of a 30-31", I'd say you'd be really close to timeslips like the guys running their 33" tires on 3.92 rears. Just the other end of the spectrum.
Old 04-10-2013, 07:25 AM
CmRam's Avatar
Rep:52
Ok I'll go with the 4.10s then!!! Thanks for everyone's input
Old 04-10-2013, 07:43 AM
CmRam's Avatar
Rep:52
They are stock 20s with 275/55r20 which are 31.25 in diameter, I measured them when I set my tire size on my sc. It's just crazy because a couple of people have said they have a few less mods same gears and everything running about the same, I actually set everything back to stock later last night and did another 0-60 run just to see what my bolt ins added and ran 7.5 0-60 which I did bone stock
Old 04-10-2013, 07:00 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
The bolt-ons won't make much difference at all without a tune installed. The factory tune is going to limit fuel and timing, regardless.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 04-10-2013, 08:03 PM
CmRam's Avatar
Rep:52
I just might switch to diablo sport tuner there's a couple of guys on here that have either fewer mods,bigger truck, or larger whelks and tires running with faster 0-60 times maybe the flashpaq is no comparison and my time was on the 93 tune of course with 93 octane.
Old 04-11-2013, 12:14 AM
EZStreet8 EZStreet8 is offline
Vehicle: 2013 Dodge Ram 1500 Laramie
Color: Bright White/Silver
EZStreet8 is on a distinguished road
Don't forget, if you put a 4:10 gear set in and then go to a larger tire diameter, you don't have a 4:10 ratio anymore. You probably end up with a 3:92 or a 3:73 / 3:55 depending on how much bigger you go in tire diameter.
By the same token if you went to a smaller tire size than your stock 20" tires you'd go from say a 3:55 stock rear end ratio to maybe a 3:92 just by going to a smaller diameter tire. I'm sure there is a formula to calculate it.
Remember if you go to high numerically/low in ratio you'll probably have a lot crappier gas mileage than you have now and an annoying drone on the highway and don't expect to be cruising at high speeds unless you want to watch your gas gauge needle physically move, as your driving.
EZ
Old 07-15-2013, 07:43 AM
Prochargedram's Avatar
Prochargedram Prochargedram is offline
Vehicle: 2010 Dodge Ram R/T 1500
Trim Level: R/T 5.7Hemi
Color: Blue
Prochargedram is on a distinguished road
good info EZ...
makes a lot of sense!..
Old 07-19-2013, 12:03 AM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
That sounds about right to me. My truck is stock and I run high 6's 0-60 and because of the weight difference I easily walk away from a QC so you getting 6.8 0-60 is a big improvement IMO.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
