Tire Size - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 04-09-2013, 06:56 PM
ELOOSECANNON
Default Tire Size
OK, this has probably been beaten to death by now, but I couldn't find anything to help with the search feature. I have a 2012 Quad Cad 4x4 with 20in. wheels and a 2.5 in. leveling kit. I am still running the stock 275-60R20 tires on it. What is the biggest tire size I can run without rubbing. Just to say it up front, I REFUSE to use a wheel spacer. Any help will be greatly appreciated.
Old 04-09-2013, 07:27 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
it's interesting you couldn't find the answer to this using the search function. it's probably one of the top 3 questions asked on this forum.
with the stock wheels u need a narrower tire than say a 35x12.5x20. u could only go that big if u used spacers or a lower offset wheel. so, keep in mind u need to keep it less than 12.5" wide, probably 11ish with stock wheels.
some people say they've been able to clear 35x12.5 with either very minor rubbing or no rubbing at all. but depends on the tires ACTUAL dimension. like my 35s are not even a full 12" wide not 12.5" like written in the side wall
keep searchin. adjusting your key words, guarantee ull find something
Old 04-09-2013, 07:36 PM
ELOOSECANNON
Thanks for your help. Everything I've found on the search talks about having to use a wheel spacer. Call me old school, but I don't like the thought of a wheel spacer, lol.
Old 04-09-2013, 07:39 PM
Rep:1900
I don't like it either, so I just went with new rims. problem solved
Old 04-11-2013, 02:59 PM
kito's Avatar
kito kito is offline
Vehicle: 2012 Doge Ram
Color: Deep Cherry Red
kito is on a distinguished road
I have a 2.5 leveling kit with 35 12.5 on 20 in stock wheel and it only rubs at full lock but im cool with it looks good
Old 04-11-2013, 03:03 PM
kito's Avatar
And i didnt use wheel spacers
Old 04-12-2013, 06:49 AM
Rep:1900
Ya, I think there is a critical piece of info left out when people discuss whether 35x12.5 fit with spacers or not...
It's the difference between what people mean by "Will I rub?"
Person 1 might mean "yes you will rub, and rub bad so you can't even drive it"
person 2 says..no I installed with no rubbing...and what they really mean is "it rubs, but only at full lock and that's easily avoidable)
person 3 says...I don't rub AT ALL anywhere.
Depends on the truck..and the persons definition of "rubbing". My point is...someone might tell you "yes you can fit these tires no problem! They might rub at full lock but who cares?"
Where as the next guy REFUSES to rub ANYWHERE so tells you his tires don't fit...
Am I making sense?
Old 04-13-2013, 01:43 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
There are some running a 295/60 will work without any issuer and and 285/65 will fit. I have seen trucks with 295/65's on stick wheels also. They are all less than 12.5 wide. I run a 285/60 and they fit before the 2" level, there is plenty of room for a taller tire but anything over a 295 and there is a chance of rub with stock wheels. I had 305/55's on my stock wheels on my 09 2wd and they fit but they were a little wide and rubbed the sway bar near full lock on hard turns and parking.
