Bilstein 5100 questions - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-08-2013, 01:13 PM
Taran2011 Taran2011 is offline
Vehicle: 2011 Dodge Ram
Taran2011 is on a distinguished road
Originally Posted by nfd538 View Post
If its just the Bilsteins most like the 2.1 setting.
I have the bilstein 5100 adjustable shocks. Is that still 2.1 then?
Old 06-09-2013, 01:09 PM
nfd538's Avatar
nfd538 nfd538 is offline
Vehicle: 2017 Ram 1500
Trim Level: Sport crew
Rep:16
nfd538 is on a distinguished road
Not sure what your asking? If you have just the Bilsteins then yes the 2.1 setting for a leveled look.
2017 mods so far:
DeeZees tailgate assist, 20%tint, BT catch can, tinted tails
Old 06-10-2013, 11:56 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Originally Posted by Ryan2011Laramie View Post
where can you find the bilstein 5100 shocks for a 2011 2wd model??
Are you looking to use the Bilstein 5100's to level your 2wd? Because that's not possible. I'm not sure what is all out there to level the 2wd's. I think CST makes a 3" level. There's probably few other companies out there as well.
Does anyone know what the fronts shocks have to be set at to level out the truck? My truck still sags a little bit in the front
It completely depends on your truck. Not all of them come from the factory at the exact same height. They're all a little bit different. In order to find out exactly where you need them set you should measure your truck front and back and figure out what your rake is. Then you can find out what to set your Bilsteins at. Keep in mind if you set it dead level front and back it will probably look nose high. 0.5" - 1" of rake will look level to the eye.
