Old 04-11-2013, 09:06 PM
blackrain86's Avatar
blackrain86 blackrain86 is offline
Trim Level: Outdoorsman
Color: Western Brown
Rep:33
blackrain86 is on a distinguished road
Now I am curious! I want to buy a set before I go on any trips now!
Old 07-20-2013, 06:31 AM
2013RamOwner 2013RamOwner is offline
Vehicle: 2013 Ram Laramie 4x4 Crew Cab
Trim Level: 26H Laramie-8 Speed
Color: True Blue Pearcoat
2013RamOwner is on a distinguished road
I got an assortment pack of Cooper-Bussman Micro Fuses from AutoZone. They were in the fuse section and have a yellow package labeled ATR.
Old 09-10-2013, 09:07 AM
JsonR JsonR is offline
Vehicle: 2013 Dodge Ram
Trim Level: Laramie Longhorn
JsonR is on a distinguished road
Default Solution
I am going to order one of these today. It is the only possible solution I have found so far.... Scroll down to the pigtail tap.
http://www.tessco.com/products/displ...bgroupId=95152
Old 09-10-2013, 09:49 AM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
have all the fuses changed over to this style or just a select few "impostant" ones?
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 09-10-2013, 10:51 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
I just took a regular fuse tap and did a little trimming and bending on it with dikes and needle nose. Took about 30 seconds to make it fit/work just fine in the '13 fuse panel.
There is a fuse for the rear 12V outlet that has two position provisions. Moving it makes the rear 12V outlet constant hot instead of keyed. Moving it also leaves a known ignition-on hot slot open in the fuse panel - that's where I put the tap after a few seconds massaging it into the smaller required shape.
Easy-easy. Cheap-cheap.
- DAA
Old 09-10-2013, 10:54 AM
DAA DAA is offline
Rep:352
P.S...
There are at least a couple spare fuses in the fuse block of my '13.
The map/legend of fuses is printed on the inside of the fuse box lid. It lists the spares and their location.
- DAA
Old 09-10-2013, 10:39 PM
- DAA
You have a lot more patience than I do. I tried to mod one a few months ago and gave up and hooked a stripped wire around the tip and was done with it. Now I have to install the same kit on my personal truck and would like to make sure it's a cleaner install. The pigtail tap is the only Micro2 tap I have been able to find.
Old 09-10-2013, 11:37 PM
pvm171's Avatar
pvm171 pvm171 is offline
Vehicle: 2013 ram 1500 longhorn
Trim Level: longhorn
Color: western brown
pvm171 is on a distinguished road
You can purchase the Micro2 fuses at:
Ebay under listing "2012 Ford Micro2 fuses"
4 each size for about 13.00 and free shipping"
Old 06-22-2014, 12:19 PM
MarineRecon MarineRecon is offline
Vehicle: 2013 4x4 Ram Crew Cab
Color: Candy Red
MarineRecon is on a distinguished road
This is just plain stupid...I blew a 20A fuse on my 2013 Ram 1500 and no auto parts or hardware store I've found has them...Oh what a feeling
