Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 04-04-2013, 09:54 PM
pitcher3853's Avatar
pitcher3853 pitcher3853 is offline
Vehicle: 2009 Ram 1500 TRX4
Trim Level: TRX4
Color: Detinator Yellow
pitcher3853 is on a distinguished road
Default Battery charging warning light keeps coming on
Hello,
I have a question for all of you gear heads out there. The battery charging system warning light keeps coming on every once and awhile (The red battery symbol). There is no rime or reason for when it comes on and all I have to do is pull over and turn the truck off and restart it and it goes away and the battery needle returns to the normal position. I do not know if it is a loss connection or what. Thanks for the help!
It is a 2009 Ram 1500 4.7l trx4
Old 04-05-2013, 12:17 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Trim Level: ST express
Color: Grey
Rep:195
Sounds like your alternator is dying. Could be a bad connection, though. Or even the battery. Take to an auto parts store and check your battery and charging system. Make sure to get the guy that knows what he's doing, though.
Old 04-05-2013, 06:35 PM
Trim Level: TRX4
The battery was replaced around 1000 miles ago and they also checked the alternator. I hope it is just a bad connection since the truck only has 40k miles..
Old 04-05-2013, 06:59 PM
Rep:2737
One of the Dodge Techs in here mentioned that a battery has to have a complete charge on it for the Dodge alternator to function properly
A battery when purchased does Not have a full charge on it & the alternator will put out just enough charge to replace what was used in the starting process, it will not continue charging until the battery is FULLY charged
I run more lights then most people do & sometimes for days at a time, my gauge needle is exactly center when all my lights are on
I run my headlights whenever the key is on & when i am with a Oversized Load, my rotating lights are on & then there is my high powered CB radio
In this picture, my headlights are not on, i had not yet discovered the way to make them work whenever the key was on
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
Old 04-07-2013, 12:58 AM
RyanJM's Avatar
RyanJM RyanJM is offline
Trim Level: Express RC
Color: Black Express Package
Rep:67
I can say don't let when you last replace the battery mean you shouldn't have it checked. I have gotten a few bad batteries in differs cars I own over the past couple years. I got a junk optima red top that lasted less that 1k miles in my trans am before dropping a cell. They don't seem to be made as good these days.
I would have it checked and if its low get it charged. They can check the alternator at the same time. Also check every connection to make sure there tight and free of any corrosion.
Old 04-07-2013, 10:28 AM
RAM EM's Avatar
Color: Grey
Rep:195
When you replaced the battery were you having the same problem? If so, I would be suspect of the alternator. It sounds like it's not keeping a good charge. But of course you want to check your connections and the battery as well. Have them run more than one test on it, or have it checked at a couple of different places.
Old 04-08-2013, 11:27 AM
Trim Level: TRX4
The problem was not happening before the battery was replaced. The battery was replaced because the truck was having a hard time cranking and the dealer said is was a low battery. The light started coming on about 1k miles AFTER the battery was replaced.
Also, do any of you know where the sensor would be located? I'm good with mechanical but electrical stuff scares the piss out of me
Old 04-09-2013, 11:20 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
I would suspect a poor charging system at this point. Check you connections! Check the voltage on your battery with the engine running, it should be north of 13.5-14.5 amps. if less than that, the charging system is weak, or cables/connections are in need of attention.
Old 04-15-2013, 01:30 PM
Trim Level: TRX4
Turned out to be loose wires ant the integrated power module connection which caused a charging system high output fault. Simple fix. Thanks for all the input!
