TLC & McGaughy's Lowering Springs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Diesel Forums!
Dodge Caliber
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Place your Ad Here!
Old 04-09-2013, 11:51 PM
SHOCKWAVE SHOCKWAVE is offline
Vehicle: 2011 RAM 1500 SPORT
SHOCKWAVE is on a distinguished road
Default TLC & McGaughy's Lowering Springs
I have a 2011 RAM 1500 Crew Cab Sport 4x4 and I have hated the rake it has from the moment I drove it off the lot. I am finally getting around lowering the rear with the McGaughy 44055 rear lowering springs.
I tow a 25' performance boat and my truck levels out with boat in tow. I'm assuming I will sit low in the rear after the spring swap when towing. The TLC setup should provide a level ride height...if they work with the lowering springs. Can anyone verify compatibility? Thanks.
Old 12-20-2015, 03:19 PM
journeywork journeywork is offline
Vehicle: 2014 Ram
journeywork is on a distinguished road
I'm looking at the same set-up for my Ram. Did you ever find out if the TLC system works with a 2" rear drop?
Old 12-21-2015, 02:21 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
We have not released a version yet.
I would like to run by my guys.
Please let me know the distance between the bottom plate on top of the axle and the metal cup that holds the jounce bumper.
Thank you.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 07-24-2016, 12:05 AM
Vehicle: 2014 Ram
Any news on a version that works with a 2 inch rear drop spring kit?
Old 07-25-2016, 04:39 PM
TLC John's Avatar
Rep:17
Sorry, no
Total Load Control™
