Old 04-19-2013, 04:17 PM
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
Can you slide the bars forward? Most aftermarket ones, you can. I like the looks of them, but I think they should be slid forwards a tad, and I hate the mounting system of the Mopar bars.
Old 04-21-2013, 04:33 PM
TLSXD's Avatar
TLSXD TLSXD is offline
Vehicle: 2012 Ram 1500
Trim Level: Limited
Rep:17
TLSXD is on a distinguished road
OP were you able to get some bracket/mounting pics?
2012 Ram 1500 4x4
Laramie Limited
GROUND FORCE - SRT 22 - TOYO - SPOHN - HELLWIG - BORLA - ARH HEADERS -RETRO HID - UNDERCOVER - LINE X - BILLET TECH - TRINITY (collecting dust)
Old 04-21-2013, 07:27 PM
Hardware's Avatar
Hardware Hardware is offline
Color: Black over Grey
Rep:31
Thought I subscribed...trying again...
Old 04-22-2013, 03:19 PM
Silversport74's Avatar
Silversport74 Silversport74 is offline
Silversport74 is on a distinguished road
Okay,
Here's two pics on the mounting of the boards. The first one shows under the running board. This is all fully assembled out of the box. I took this one to show that i have no room to loosen the nuts and slide the board forward. I guess this has changed with the 2013 rams. Sucks but oh well.
The second pic is on the four bolts that go through the bracket into the truck. The two larger bolts go through the bracket into the rivnuts. The two smaller, closer together bolts go through the sheet metal under the drivers and passenger doors. These were predrilled from factory, a plus for the 2013's compared to previous years.
As the brackets really line up perfectly for installation, this leaves little room to move back and forth.
Hope this helps and is what everyone wanted. They install exactly like oval mopar bars would.
Old 04-22-2013, 05:37 PM
TLSXD's Avatar
Trim Level: Limited
Rep:17
Thankyou for the pics
2012 Ram 1500 4x4
Laramie Limited
Old 05-30-2014, 07:45 PM
timothyecklebarger timothyecklebarger is offline
Vehicle: 2014 ram sport
Trim Level: sport
Color: ganite
timothyecklebarger is on a distinguished road
Default Fitment
I realize I'm a year late on this but in researching the boards I wanted I almost didn't buy these because of they extended past the cab until I realized this truck pictured is a quad cab not crew. The boards are apparently the same for both. Makes no sense mopar doesn't make one for quads that fit right.
