Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-10-2013, 10:16 PM
GSmoggie's Avatar
GSmoggie GSmoggie is offline
Vehicle: 2012 Dodge Ram 1500
Rep:35
GSmoggie is on a distinguished road
Default Hauling weight in the bed
Took a load of scrap in the other day...Yes it terrifies me throwing a bunch of pipe into the bed of my truck, BUT it will always be a truck to me...ANYWAYS, equaled out to 1280 lbs of steel in the bed. The truck was pretty much sitting level with the load in it, but It didn't really effect power...at all. and In the 21 mile travel, the Bully Dog showed 17 mpg on the way to the scrapyard (all backroads). I was decently impressed to say the least!
What's the most you guys ever put in your beds?....That question could be taken in such a bad direction...
Old 04-11-2013, 06:23 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2015 Dodge ram 2500
Trim Level: Tradesman
Color: Granite Metalic
Rep:81
no more than 600lbs so far. my 05 ram 3500 dually I had 2600lbs in it. and it sat pretty close to level with that load.
2015 Ram 2500 Tradesman, 275/70/18 Fierce Attitude M/T, 18x9 ?wheels, Custom 13' OEM projectors, 55w 5k HID's, 7" premium display cluster swap, Alpine INE-Z928HD HU, RF 200s amp, 2 10" MTX subs, Factory bumper with fogs added
Old 04-11-2013, 07:30 AM
GSmoggie's Avatar
Rep:35
I would like to hear from yah again if you ever get some more weight in there...love to know what happens with that lift you have.
Nice looking rig by the way!
Old 04-11-2013, 12:44 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:131
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
Here is a pic of my 2500 hauling 300 gallons of water. At roughly 8.3lbs per gallon (2,490lbs total), toolbox, and other tools the truck handles it like a champ. I've hauled the same load in several other 1/2 ton trucks and they would all haul it (barely) but they were hurting badly doing it.
Old 04-11-2013, 12:51 PM
GSmoggie's Avatar
Rep:35
Nice!! Gotta love it! She's taking care of that load like clockwork man. How does nearly 3000lbs effect your power?
Old 04-11-2013, 01:02 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
She was about 315lbs...but she was a sweetheart.
oh..wait...
I picked up two truck bed fulls (above the bed rail) of pea gravel. I think a little over 1000lbs each load. She squatted a good bit..and only drove it a mile to my house and into my backyard. Interesting experience, my backyard slopes a bit and was squeezing through my fence gate which is barely wider than the truck. So i had to pull forward and up the grassy hill a few times. with the truck in 4wd, it'd idled up the incline without even touching the gas.
Old 04-11-2013, 01:48 PM
GSmoggie's Avatar
Rep:35
First off, well played sir...well played.
For the truck, that's awesome! Up a slight incline, in 4wd, and still idled up that piggy with half a ton on it. Good stuff.
Are you running the 3.55 gears in that truck?
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
I also hauled water in my truck, it was a 2007 4x4 Quad Cab. It was a 250 gallon tank. It comes out to about 2000 lbs. It squatted it down in the back. I did this to fill my swimming pool, so I hauled probably 100 loads, maybe 5 miles one way. This is one reason I ending up buying a 3/4 ton. Of course since I've had the 3/4 ton, I've never used it for anything a half ton wouldn't have done.
Keep in mind these trucks will usually tow a lot more weight than you can put in the bed of the truck, so power is rarely a problem when hauling a load in the bed.
Old 04-11-2013, 01:54 PM
Rep:1900
I have 3.92 gears in my truck
Old 04-11-2013, 01:57 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
I had a 9L Volvo marine diesel with ZF 305 gear. I'm not gonna tell you what it weighed, but a lot. I'd say my 31.5' fifth wheel travel trailer has almost that much bed weight. BTW my dealer installed extra leaf in the back and Rancho 9000's when my truck was new. 3:92's, wish I had 4:10's, but it tows well.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
