Old 04-11-2013, 12:57 AM
RyanDicks RyanDicks is offline
Vehicle: 2011 Dodge Ram 1500
Color: Gray
RyanDicks is on a distinguished road
Default Bully Dog GT for Hemi Plus
Can someone tell me whats the best shift points to have the tuner at?
Thanks,
Old 04-11-2013, 07:02 AM
1500ram12's Avatar
1500ram12 1500ram12 is offline
Vehicle: 2010 Dodge ram
Rep:81
For the regular tune I maxed out the WOT shift points. For Performance I think I had mine at 100 less than the max
2010 Ram 2500 SLT 6.7L Cummins, S&B CAI, H&S Mini Maxx Race Tuner, DPF Delete, EGR Delete, Bilstein 5100's, raceland 4" e-cutout
Old 04-11-2013, 08:07 PM
stricnine's Avatar
stricnine stricnine is offline
Vehicle: 2011 Hemi QC
Trim Level: sport
Color: silver
Rep:65
stricnine will become famous soon enough
I keep mine stock, these trans. suck so I don't push it.
2011 HEMI Quad Cab w/ 3.92's; K&N Aircharger; Belltech 2/4 Drop; BT Catch Can; Truxedo Lo Pro QT
Old 04-12-2013, 06:49 AM
1500ram12's Avatar
Rep:81
the regular tune only can be raised maybe 500-600 over stock and performance tune is raised maybe 1000 over stock. raising where the shift points are isn't going to hurt these transmissions. You start adding over 100 hp than your going to start running into problems
Old 04-12-2013, 07:18 AM
FireWire's Avatar
FireWire FireWire is offline
Rep:12
FireWire is on a distinguished road
Won't Tow/Haul mode do pretty much the same thing?
Old 04-12-2013, 03:47 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Are you trying to suggest that tow/haul mode does pretty much the same thing as a tuner? Changing shift points is only one small thing that the tuner does....
But no using tow/haul is not the same thing at all. The shift points still won't be higher at full throttle than what they are set at stock. Tow/haul does hold the gears longer under normal driving to keep the truck up in the power a bit more. That doesn't change the WOT shift points.
