Old 04-11-2013, 02:35 AM
Kelevra's Avatar
Kelevra Kelevra is offline
Vehicle: 2012 Dodge Ram
Rep:91
Kelevra will become famous soon enough
Default MDS? Eco indicator?
Ok, few questions here. I've come across conflicting info as well as I have some concerns with MDS/Eco
First, is the Eco light in any way dirrectly related with the MDS coming on or going off? if eco is on is MDS on and vice versa or will the eco light sometime be on and not MDS or Eco be off and MDS be on?
The reason I ask is when I'm cruising (cruise control on) on the highway at 65-70 MPH the Eco light is seldom on. Does this mean my MDS is off when cruising at those speeds?
Old 04-11-2013, 03:32 AM
TexasBorn TexasBorn is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Lone Star
Rep:99
TexasBorn will become famous soon enough
when you see the ECO light/icon come on, that means MDS is active. inversely, when it's not on, you're running on all 8 cylinders. it's based off of throttle percentage and how much power the truck needs to either accelerate or keep speed. the reason it goes in and out when cruise control is on, is because of various road conditions: hills, strong winds, turns, etc... the engine has to work a little harder to maintain the speed when these arise. a good way to test it, or to see this happen on command, accelerate like you normally would, and then come off the accelerator and you'll see the ECO light come on as you coast. it's a good concept, but it's not perfect. the whole idea of MDS is roughly "power when you need it, economy when you want/can". it takes some getting used to and you'll see when your truck will and won't activate MDS. hope this helps!
Old 04-11-2013, 09:39 AM
Moose612 Moose612 is offline
Vehicle: 2006 Ram 2500
Rep:26
Moose612 is on a distinguished road
I'm not sure it actually means that MDS is on. It does have to do with throttle percentage yes, I turned MDS off with the trinity and the eco light still comes on.
Living the dream.
Old 04-11-2013, 10:20 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Eco light is just an indicator to indicate you are presently driving your vehicle in the most Ecological manner possible, that being said, it can be with MDS on or off. that being said again that your MDS will engage also when the truck sees there is no need for all 8 Cylinders to be running, and that would be usually when your driving the truck in the most ecological way. If you down shift to 6th gear disabling the MDS, and be nice on the pedal you will see the Eco light comes on when it feels your driving her the most ecological way.
Old 10-11-2013, 05:17 PM
rdrnr1963's Avatar
rdrnr1963 rdrnr1963 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Sport Quad Cab 4x4
rdrnr1963 is on a distinguished road
Forgive the ignorance here. I'm a former (older ram) owner from years back and a new 2013 owner, and have been doing a TON of reading on the MDS / ECO features of the new Rams. I have yet to EVER see an ECO light come on anywhere in the instrument cluster, and I can't find any options in the EVIC system (both instrument cluster AND UConnect Apps / Settings mentioned in other threads) for turning the ECO mode/indicator On or Off. Can someone please elaborate on how those settings are accessed? Thanks in advance.
Old 10-11-2013, 05:22 PM
Radak04's Avatar
Radak04 Radak04 is offline
Vehicle: 2013 Ram Sport Crew
Rep:76
Radak04 will become famous soon enough
I turned mine on in the settings on my nav system. Not at my truck now, so not sure exactly what menus I went through.
When it's on, the green ECO light comes on the bottom of my dash a little left of center.
It's bright green when it's on and hard to miss.
Old 10-11-2013, 05:34 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
+1 with Asur's explain, spot on.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 10-11-2013, 07:50 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
I've got a '12 with hemi. When driving in 6th in ERS mode, I've never seen the ECO indicator come on. As soon as I shift to D under same conditions it will often come on.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 10-12-2013, 08:55 AM
Red-Stripe Red-Stripe is offline
Vehicle: 2012 ram
Rep:117
Red-Stripe will become famous soon enoughRed-Stripe will become famous soon enough
Mine's the same way. The cruise's closed loop is programmed too aggressive to try and keep the truck speed within 1mph of the setpoint, so it too frequently exceeds the maximum TP. Try driving with it off, and hold the pedal steady, and you should see the "eco" stay on much more often.
