tonneaucovered.com
Old 04-11-2013, 11:46 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Default Tire & wheel fitment & sizing reference thread
**My portion of this thread is going to be limited to what I know which is primarily the 20" tire sizes (and thereby the third gen and fourth gen trucks). If someone with knowledge of the stock 17" fitments, older trucks, or even aftermarket fitments wants to add, please do so.
It seems like we get a lot of questions in the tire and wheel section about basic fitment issues and recommended tire sizes. A lot of the questions have been answered before and could be found with a search but as someone that has spent hours upon hours slogging through search results, it's always nice to have a go-to for at least the basic info. With that in mind, I started this thread. If it's needed and it helps, great. If not, at least I have a thread I can link to when I see these questions, lol.
I am no expert by any means. Most of my knowledge comes from those hours of searching and reading both here on our forum and other places on the web. With that in mind, if you see something that you think is incorrect or needs to be added, please let me know.
First, some quick facts:
* All third gen 20" rims are 9" wide
* Fourth gen 20" rims can be either 8" or 9" wide. To the best of my knowledge the chrome clads are 9" and the painted rims are 8".
* Here is a good site to visit if you don't know for certain how wide your rims are. Simply pick your model year and match the photo.
http://www.finishlinewheels.com/DODGE/RAM+%C0+TRUCK/
* I believe some early third gen 4x2 trucks came with 275/55/20 stock. However, most trucks, particularly more recent models come with 275/60/20 stock. 275/60/20 is a 33" tall, 10.8" wide tire.
* As stated above, stock is a 33" tire. All third and fourth gen trucks can run a 34" tall tire stock and a 35" tire with a proper level. This is height only...for info on width, see below.
* 17" diameter rims are the smallest that will clear the brakes on third and fourth gen trucks!
Sizing, fitment, and other info by model year:
* Early third gen (2002-2005) Ram owners are lucky in this regard. These trucks have torsion bar front suspensions that eliminate the clearance issues that newer trucks have. These trucks can run 305mm wide tires bone stock. As stated above, that means they can run 35x12.50x20 with only a level!!
* Newer third gens (2006-2008) and fourth gens (2009-present) are generally limited in width by the upper control arms. If you search, you will find differing comments regarding what fits and what doesn't. One owner will report that a size fits with minimal rubbing while another may report the same size runs with zero rubbing. While some of this may be due to differing tolerances on the trucks themselves, I would tend to guess it has more to do with variance between tire manufacturers and models. The general rule is that 285 is the widest that will fit on stock rims and without spacers.
* Exception for fourth gens with 8" wide stock rims: There is an exception to the above general rule for fourth gen trucks with the stock 8" wide rims. The narrower rim pulls the sidewall in more than the wider rim and allows fitment of a wider tire. Members with the 8" rims have confirmed no rubbing with 295/60/20 and 295/65/20. I personally have not seen confirmation of anything wider fitting but that doesn't necessarily mean it will not.
Fitment and other info by tire size:
All of these are compared to stock 275/60/20 (33x10.8x20). Please note that while comprehensive, this is not a list of every single tire size available for the 20" rims but simply some of the most popular.
* 275/55/20 (32x10.8x20) = Same width as stock, 1" shorter than stock, great selection, slightly cheaper or same price as stock.
* 275/65/20 (34x10.8x20) = Same width as stock, 1" taller than stock, large selection and not overly expensive compared to stock.
* 285/50/20 (31.2x11.2x20) = 0.4" wider than stock, 1.8" shorter than stock, great selection, slightly cheaper or same price as stock, used a lot on lowered trucks with stock rims.
* 285/55/20 (32.3x11.2x20) = 0.4" wider than stock, 0.7" shorter than stock, somewhat limited selection, fairly expensive.
* 285/60/20 (33.5x11.2x20) = 0.4" wider than stock, 0.5" taller than stock, very limited selection and expensive.
* 285/65/20 (34.6x11.2x20) = 0.4" wider than stock, 1.6" taller than stock, very limited selection and expensive.
* 295/60/20 (34x11.6x20) = 0.8" wider than stock, 1" taller than stock, limited to only the Nitto Terra Grappler all-terrain that I am aware of, expensive but a good blend of wider and taller.
* 295/65/20 (35x11.6x20) = 0.8" wider than stock, 2" taller than stock, limited to only the Nitto Trail Grappler mud-terrain that I am aware of, expensive.
* 305/50/20 (32x12.00x20) = 1.2" wider than stock, 1" shorter than stock, pretty good selection, priced comparable to stock size.
* 305/55/20 (33.2x12.00x20) = 1.2" wider than stock, basically same height as stock, great selection, somewhat expensive.
Spacers? What about spacers??
When I say spacers I am referring specifically to the 1/4" spacers that are required on most 2006-up trucks to clear some of these tires sizes. Some people use them and love them, some people wouldn't even consider running them, and some people simply don't know. So here's the facts. Lots of owners run cheap ($20-30) off the shelf universal spacers with absolutely zero issues. Many owners have shown that there is more than enough lug stud to run a 1/4 spacer with no increased danger of lug runoff. Checking lug torque periodically is certainly a good idea but that's the case even if you aren't running spacers. The only potential issue with universal spacers is that they do not fit the hub or lugs tightly and are therefore difficult to center on the hub. Some owners have experienced balance/vibration issues because of this. The solution is a set of hubcentric spacers from Motorsports Technologies. These spacers are basically the best you can buy. Hubcentricity guarantees that the hole in the spacers fits snugly around the hub thereby guaranteeing that they are centered. Seems like these spacers can be had for around $125/pair or maybe slightly less than twice that for a set of four. You can find them here...
http://www.motorsport-tech.com/
Alright, that's all I got. If I think if anything else to add I will and as I said, if anyone has any suggestions please throw them my way. Hope this helps someone.
Old 04-11-2013, 11:54 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
Rep points for this. Nicely collated info.
285/65/20 BFG TA KO2s, Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 04-14-2013, 11:26 AM
BoOdOg's Avatar
BoOdOg BoOdOg is offline
Rep:22
BoOdOg is on a distinguished road
great post thank you, this will help me as Im currently looking for a rim/tire setup
Old 04-14-2013, 11:42 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
thank you!!!! great post
Old 04-18-2013, 12:21 PM
CanuckHRAM's Avatar
CanuckHRAM CanuckHRAM is offline
Vehicle: 2011 Ram Quad Cab 4 x 4
Trim Level: SLT Outdoorsman
Color: Deep Water Blue Pearl
CanuckHRAM is on a distinguished road
Excellent Post & great work! - you lucky 20" rim owners. This type of info. would be great for us 17" rim owners but so far I do not think anyone has gone to this effort yet. Reps for you!!
Raider Phantom Topper, K&N Drop-In Air Filter, Vent Visors, SmittyBilt Light Bar & PIAA Lights
Old 04-18-2013, 12:24 PM
Rep:1900
really shouldn't matter that much between 17" and 20". The only difference is the width of the wheel. So that's all u need to get an eye one, whether you chosen tire can be mounted on whatever width your wheel is.
It's really about the overall tire diameter in the end. Not saying there aren't things to consider when having 17" wheels, but it should be most the same info
Old 04-18-2013, 12:50 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
Awesome post! Been trying to find this information by searching and browsing through posts.
Old 04-18-2013, 02:19 PM
madhatr02's Avatar
madhatr02 madhatr02 is offline
Vehicle: 2014 Ram 2500 HD
Rep:145
madhatr02 will become famous soon enoughmadhatr02 will become famous soon enough
Awesome post. But how do I know if I need spacers? Want 305/55 on stock 20's.
*edit* saw you said 285 was widest without spscers.
Also does 2wd or 4wd matter? Assume this post is 4wd.
And rep points!!
Semper Fi,
Kevin
2014 2500 HD
aka "Big Red"
Old 04-22-2013, 10:25 AM
sumncguy sumncguy is offline
Vehicle: 2012 Ram Crew Cab Express 4x2
Rep:16
sumncguy is on a distinguished road
Havent been back in a while.
Have had a 2012 RAM Express for a while now .... I personally want to dump these 20" wheels .... I have a street truck, I use it as a truck .. not a pimp mobile ...
Im searching all dodge truck forums for show one who wants to work out a reasonable trade .. or, Ill go to a junky and get the 17 clad and lets the 20's sit on craigslis and/or ebay until they sell.
Old 04-25-2013, 10:30 AM
CanuckHRAM's Avatar
I agree with you gonefishin776. There are definitely some pricing differences in the 17" tire sizes - especially the LT275-70-17 Rubber my Outdoorsman has - very few tire manufacturers selling in this size. Moving up to a slightly bigger dia. LT285-70-17 gives you way more selection and actually cheaper costs in most cases.
