Old 11-05-2013, 05:17 PM
Slawitschkafam Slawitschkafam is offline
Vehicle: 2014 Dodge Ram
Trim Level: Tradesman
Slawitschkafam is on a distinguished road
Default 305/65/18
Ok I've searched quite a bit and haven't seen where anyone has tried this and was wondering if 305/65/R18 BFG AT on 18x9 XD Monsters will fit on my 2014 1500 4x4 tradesman with a 2" leveling kit?
I see a lot of people going with the 285/65/18 but according to all the measurements a 305/65/18 should fit.
Thanks for any input/advice!!!
Old 11-05-2013, 05:19 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2036
What is the offset of the wheels you're looking at? That's what will determine if they fit or not. Height wise it's not an issue at all.
Old 11-05-2013, 08:33 PM
4.5 is the back space. Thanks for the quick response!!
Old 11-05-2013, 08:35 PM
They are 18x9 5x5.5 4.5 BS
I'm not sure what the actual offset is. I will find out tomorrow but I believe it is a 0 offset.
Ok I take that back, the monsters are showing -12 for my truck it was the xd misfits that were 0 offset.
Knowing that what do you think?
Thanks!
Old 11-06-2013, 01:47 AM
Rep:2036
Yup, 9" wide rim with 4.5 inches of backspacing is a -12 offset. Here's a chart showing the relationship between offset and backspacing.
You won't have any issues running that set up. Tons of clearance. You could run a bigger tire if you wanted too. But the 305/65/18 should fill out your wheel well quite nicely with the 2" level.
Old 11-06-2013, 11:24 AM
Great!! Thanks for the advice. I will post pics once it's done.
Old 11-14-2013, 10:31 PM
buddyb buddyb is offline
Vehicle: 2011 Ram 1500 Laramie
buddyb is on a distinguished road
awesome post, I'm getting my wheels tomorrow
Old 11-27-2013, 11:25 PM
San17 San17 is offline
Vehicle: 2004 Dodge Ram 1500
Trim Level: high ... Laramie ?
Color: grey
San17 is on a distinguished road
First post I read as a new member and I found in 5 minutes answers I was looking on my own for months !
thank you very much
Old 11-28-2013, 12:44 AM
Color: grey
Thanks for all these usefull informations. I must be lucky as I own a 2004 .
I would like to change my 20" (265/70r/20) with something 50/50 road-offroad
My idea was 33/12.5/17 but I don't want to make modifications on standard suspension and leveling system. You think it's possible or I must forget the idea ?
San
Old 11-28-2013, 02:32 PM
I went with the 305/55/20's on my new Nitto's and 1.25" spacers and 2.5" level kit
