Old 01-24-2014, 01:29 PM
alansoldcadets alansoldcadets is offline
Vehicle: 2006 dodge ram 1500
Trim Level: laramie
Color: lava red and driftwood
alansoldcadets is on a distinguished road
Ive had traction and sidewall puncture issues with stock 20 inch tires.my tire dealer says the 17 is better for traction and sidewall punctures.looking to change from 20 to 17 on a 2006 laramie 1500
Old 03-14-2014, 06:24 PM
carolinaheels1 carolinaheels1 is offline
Vehicle: 1999 Dodge Ram 1500
carolinaheels1 is on a distinguished road
Would anyone know if 32x11.50 R15's would fit on my 1999 dodge ram 1500? Current tires are 275/70/r16's 5 lug. any help would be GREATLY appreciated!
Old 03-16-2014, 07:43 PM
Grandavi Grandavi is offline
Vehicle: 2004
Grandavi is on a distinguished road
Okay, I have a 2004 dodge ram quadcab 4x4 5.7 l hemi SLT. I just bought it and it has Core Racing rims (17") with off-road style wheels.
Looking to pick up a set of take offs and there are more 20" rims than 17's available.
From what I understand, the 20's should bolt on (5bolt) with no issues and the dealer can recalibrations the speedo.
Am I correct?
Old 03-16-2014, 11:18 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2051
If they're stock wheels from a Ram you won't have any issues. The speedo only needs to be calibrated if the overall tire size changes.
Old 03-17-2014, 12:03 AM
Vehicle: 2004
Thank you for the reply.
I rewrote the question for clarity and by doing so.. answered the question myself... only took me 1/2 hour.. lol.
Old 03-17-2014, 12:49 AM
steve6755 steve6755 is offline
Vehicle: 2004 dodge ram
steve6755 is on a distinguished road
on my o4 ram,, if i crank the torsion bars to level.. add 2" blocks to rear then add front level kit to keep up with the 2" blocks in the rear,, what size tires can i put on my 20" rims with out clearance issues,, i would also like to add 1" spacers to offset the fender flares i ve added..if i go with an aftermarket rim ,,, what offset can i run to make up for a 1" spacer to eliminate the spacer..
Old 03-17-2014, 02:01 AM
Rep:2051
Cranking the torsion bars is leveling... Once they're cranked that's all you've got, you can't add more height unless you go to a full on lift kit.
I would recommend going with an aftermarket rim rather than a spacer. It will be a much better set up. The offset you need to be flush with your flares will depend on the wheel width and tire size you go with. You will be able to run up to a 35x12.5 tire.
Old 03-18-2014, 02:53 PM
TheGriz TheGriz is offline
Vehicle: 2011 Ram sport crew cab 4x4
Trim Level: Fully loaded
TheGriz is on a distinguished road
So with a new wheel, 20x9 with a zero offset and a bilstein set at 2.1 295x65 trail grappler, would there be any rubbing? Would i need to goto 2.8 or add a spacer?
Old 03-18-2014, 03:24 PM
Rep:2051
Nope, you shouldn't have any issues with that set up at all.
Old 03-18-2014, 09:47 PM
Thanks for the response! Getting ready to pull the trigger on the set up, gotta love tax season! Anyone else rocking any LRG 104's? Originally wanted the BMF SOTA's but they're $400 more for a set!
