Old 04-15-2013, 08:03 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Originally Posted by seanbeckaroo View Post
Those stupid engine builders have been screwing us for YEARS with these lousy 195 or 203 stats! I can't BELIEVE all the Dodge Engines that are just blowing up! It is in fact a MYTH for modern day engines; please provide any scientific facts to prove your theory. Engine teperatures will go to whatever they want to; T-stat can be full open at 200 degrees and it won't make a smit of difference what stat you are using. The fans and airflow provide the cooling , a stat is basically just an-on or off switch.
Lol, the stock tstats don't open until 203 degrees. I don't care how much air you have blowing on it (unless you're in sub zero temps)your engine won't run any cooler at operating temps (warmed up). If it were to never open and water didn't pass through the block you'd burn the engine up. Lol, why don't you prove your theory and just block off your tstat all together and let the fans keep it cool? Turn the switch off and show us, lol. A 180 will open up at that temp and the fans will assist in keeping it there. Water cools your block, fans cool the water. That's what a fan shroud does, it helps suck the air through the radiator fins to cool the water. And yes, air will help keep the engine cool, but without water you're engine would fry unless ur running alcohol.
Old 04-15-2013, 08:12 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
When I ran a stock stat my truck ran at 205 during normal use. When I ran a 180 stat it ran at 185. Now I run a 170 stat and it runs at 170. That is all the evidence I need to prove that a cooler stat will affect engine operating temps.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 04-15-2013, 08:32 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
OK, So has anybody with a 2012 Ram HEMI, without a tuner, run a 180 degree stat? How does it run? What did it do to MPG?
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it harder if your stupid." How would you know?
Old 04-15-2013, 08:54 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
If you run 180t with out a tuner you'll be just fine. The clutch fan start spinning at 190
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-15-2013, 09:40 PM
RadioFlyer's Avatar
Rep:146
Actually you don't need the clutch fan either.
Old 04-15-2013, 09:43 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
This is true, I removed mine and used my tuner to set my e-fan at 190.
SPONSORED BY
BULLY'S PERFORMANCE
Old 04-16-2013, 03:55 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
I'm pretty sure that's what I just said! It doesn't matter WHAT stat you use; when the engine runs hot, it runs hot. It will have no effect on your ridiculous timing theory! It will open at 180 and try to stay there; or it will open at 195 and try to stay there! Either way, you will not damage your engine by running at 195 compared to 180.
