Kit Installed - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Total Load Control - Dodge Ram Air Suspension
Total Load Control - Dodge Ram Air Suspension TLC™ is the patented air suspension that solves the problems hauling or towing heavy loads with coil springs. No modification required; keep the coil springs. Fits all 2009-16 RAM 1500 including Ecodiesel and 2014-16 RAM 2500! Spacers available for most 4" and 6" lift kits for RAM 1500
TLC also makes units for 02-13 RAM 2500 & 02-16 RAM 3500 with leaf springs.
TLC adds over 5,000 lbs of lifting power to level any load or tow with the largest air springs on any full-size pickup – 9” Goodyear® dual bellows. Your truck will be safer, handle better and go faster around curves. TLC doesn’t interfere with the factory ride. You’ve never experienced the power of air bags until you try Total Load Control™.
Easy to install; no drilling; fits leveled & body lifted trucks.
We introduced TLC on the Z and have many happy Z customers. Get Total Load Control Today !
Old 06-17-2012, 11:42 PM
LC Hauler's Avatar
LC Hauler LC Hauler is offline
Color: Bright Metalic Grey
Rep:72
LC Hauler will become famous soon enough
Default Kit Installed
Got 90% of the kit installed today, took about 2hrs to do. I didn't install the compressor yet, but I charged up the system. I did note a leak in the release valve. Not sure if anyone else has come across that issue, but I had it filled to 10lbs and an hour later it was empty. I did check all connections, and you can hear a slight hiss from the release valve.
All in all, the kit is REALLY easy to install, even the awkward nut you have to contort toinstall and tighten on the drivers bag hahahaha,
John, let me know what I can do for the leaky release valve.
kit is good and it will get it's first use this coming weekend.
here's some pics:
Gauge Install
Bag install
Auxillary Valve install
Old 06-18-2012, 12:55 PM
ArmyofOne's Avatar
Some Assembly Required
Vehicle: 2015 Ram 1500 CC 4x4
Color: Blue Streak Metallic
Rep:1260
Can you pinpoint where its leaking from? is the valve faulty and its just seeping from it?
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 06-18-2012, 10:40 PM
LC Hauler's Avatar
Rep:72
the leak seems to be coming from the little ports on either side of the release valve. If I pull the release valve slightly it seems to seal but the minute I let go, it leaks again.
all my hose and splitter connections are straight and clean, the longest of the line feed to the bags is solid.
Old 06-18-2012, 11:08 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Chris,
Sorry to hear that. It sure sounds like that valve is bad.
We're sending a replacement to you tomorrow.
Thanks for your extra effort and patience.
John
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500 4500 5500
Level Every Load with TotalLoadControl.com
Old 06-20-2012, 08:25 AM
LC Hauler's Avatar
Rep:72
^ no worries guys, no big deal, A new valve will be fine. I can still inflate and deflate the system through the aux filler, but I'm happy overall with the kit. I will take pics tonight when i load the trailer, for camping tomorrow.
Old 06-20-2012, 02:06 PM
dankent's Avatar
dankent dankent is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Rep:32
dankent is on a distinguished road
Nice work should have mine in a couple days i think.
Old 06-20-2012, 09:05 PM
Rep:3347
So this is what you've been up to lately!
Old 06-25-2012, 12:53 AM
LC Hauler's Avatar
Rep:72
^ yeah, sorry gang haven't been to many LX coffee's as of late, since we have the new trailer now, It's going to get a lot of use over the summer and fall.
Old 06-25-2012, 12:57 AM
LC Hauler's Avatar
Rep:72
the kit works great guys/gals. did the first trailer test this weekend on a camping trip. It was amazing to see the truck lift and level out at around 20lbs. It definately took the bounce out of the ride which was nice. Even had a couple of neighboring campers come over and look at the system.
Great kit guys!!!
Old 01-03-2013, 09:45 PM
scuba0331's Avatar
scuba0331 scuba0331 is offline
Vehicle: 2014 Ram 3500 CTD Crew Cab
Trim Level: Bighorn
Color: Deep Cherry Red
Rep:20
scuba0331 is on a distinguished road
LC Haler how hard was it to remove the trim to adde the gauge, switch and valve?
Very nice and clean installation!
[SIGPIC][/SIGPIC]
