Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Body & Interior
Old 04-12-2013, 01:57 AM
Wyte Mike Gilliland Wyte Mike Gilliland is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: big horn edition
Wyte Mike Gilliland is on a distinguished road
Default where is that leak coming from?
Alright, this is driving me crazy....
Have an air leak and a water leak in my 08 ram 4.7 slt quad cab. I have the loudest most aggravating air leak from somewhere on the passenger door, I feel like its coming from the window, but cant feel any air coming thru it or the door, ive tried readjusting the striker and it didnt help, and I dont know what to replace since I cant find exactly where its coming from. Has anyone else had this problem?
Also, I have water leak coming out the "oh sh*t" handle bar on my passenger side. Its a small leak that you dojt even notice unless it just really floods out there,and it comes from inside the circle fitting that covers the screws. Once again, I have inspected the outside of my truck and all my stripping looks good and of course I dont have any hole in my body, so once again im baffled. Dont want to take it to a body shop, so please someone help me!!!!
Old 04-12-2013, 05:16 AM
Rep:2705
buy some Painters blue tape & tape off the door seams from the outside
if the air no longer passes through, rip off portions of the tape until you notice it again
take off the inner A pillar cover on the passenger side & look up at the roof line, while you are using a water hose turned on just enough to coat that part off the roof with water
I am thinking that there is a tube up there & it may be blocked by leaves or other debris
If not, right behind the door seal, there are screws or holes that sometimes leak & need to be sealed
on 1 persons 2006, they discovered this:
RE: A-Pillar Leak! Update.
It appears that I found the right technician. I drove my truck in ASAP. After letting the truck warm they immediately went to the area behind the upper weather stripping on the door at the roof directly above the a-pillar handle. Behind there are the screws that hemiyellow stated were there. A very brief water test produced water in the upper screw pocket of the handle.
The handle screws were removed, the weather stripping was removed, and the truck was allowed to warm and dry out.
The upper screws were checked and not all were tight - thus the leak. The screws were backed off, after being dried and cleaned the new sealant, (RTV I believe), was applied behind and around the screws. The weather stripping was replaced and the truck was left indoors for the sealant to tack over. As it was the passenger side I will not operate it until the weekend when the weather warms.
WORD OF CAUTION: According to others and the tech this is a notorius weak spot where our trucks flex. The more twisting you do in your tuck, it does not have to be 4X4, this is where the weak link is. Most of my twisting is just uneven terrain, occasional logs/drift wood, dirt access roads and river beds. And of course snow. This was over the course of the day: while the mechanic worked on other things while my truck warmed, dried out and tacked over. Hell it didn't even get looked at until it was indoors for almost an hour - too cold. Prepare to leave your truck for a good water test and fix or a long wait.
Old 04-12-2013, 12:09 PM
Thanks bro, taped the truck off like you told me and realized it wasnt from one in particular spot, it was leaking around the whole door, not window. So I remebered a video off youtube showing a guy letting down his window, placing his knee in the door, and bending the top half of the door towards him to bend it back in shape. Problem solved, when it quits raining again and I clean up my floorboard ill check out the water leak again
