Old 04-12-2013, 07:33 PM
Ronan's Avatar
Ronan Ronan is offline
Vehicle: 2013 ram sport crew
Trim Level: Sport crew
Rep:42
Ronan is on a distinguished road
Default Bilstein 5100 install???
Just ordered my bilstein's to accommodate my 325/60/20 Terra's. can anyone give some advice on the install. What special tools I might need. Any tricks to use etc. any help would be appreciated. Can't wait to get these bad boys on my truck and make it a real truck!!!! Thanx in advance!!!
Vararam CAI, Moes 87mm, flowmaster ,20x9 DC gun metals, 325/60/20 Terra's , bilsteins set at 2.1 , access tonneau, raptor W2W nerfs, AVS ventvizors , tints.........
Proud member of LOCAL 361 IRONWORKERS
Old 04-12-2013, 07:38 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I have a plethora of information. but I'm on my phone so it'd be a pain to find all the links.
u need a spring compressor. yours shouldn't be hard AT ALL because it's a brand new truck. so u won't have the lca bushing issue us older models have. it's really a easy install ESP with a buddy. very straight forward. when are u planning on installing? if u wait till later in the weekend I can send u some links to some good write ups
Old 04-12-2013, 07:52 PM
Ronan's Avatar
Rep:42
I won't be receiving it u til around wed. So probably next weekend or some day during the week. Any help I would really appreciate as I am new to installing a lift. I've done plenty of lowering kits on cars , I am pretty handy with a wrench. How much time do you think this will consume. If it is nice out I will do it after work but I don't want it to run into the next day because I drive this truck as a daily. Thanx again man any links would be great and like I said no rush...
Old 04-12-2013, 07:56 PM
Rep:1900
I could get you plenty of info on Monday when I'm on my lap top and not drunk
with ur brand new truck and being competent, 2.5/3 hours. not even. you know how it goes... 1.5 hours the first side, then 40 min for the second side. I had a set of through sockets that came in handy like no ones business so I highly suggest a set of those if u don't have them.
Old 04-12-2013, 07:59 PM
Ronan's Avatar
Rep:42
Ok I'll pick em up, go get some more drinks and have a few for me, I gotta work tomorrow .. Booooo.... Here is a before pic for the record..
Old 04-12-2013, 08:02 PM
Rep:1900
beautiful truck!!!
shoot me a message if for some odd reason I forget on Monday. but I don't usually forget so.......
Old 04-12-2013, 08:06 PM
Ronan's Avatar
Rep:42
Thanx man , can't wait to see it with rims tires and level!!!!!
Old 04-12-2013, 08:25 PM
Rep:1900
what wheels and tires U gettin
Old 04-12-2013, 08:51 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
I installed mine. Really easy. Just be careful
1.) Remove the wheel/tire
2.) Remove the stock strut.
3.) Disasemble stock strut
4.) Assemble Bilstein Strut
5.) Set the ring at the height you want
6.) Install new strut.
7.) Repeat on other side.
8.) Get an alignment
9.) Take pictures
10.) Post them on this forum.
Honestly it is a very easy install. The only thing is when you remove the spring from the stock strut and place it on the new strut you have to be careful. Anytime you are dealing with coils/springs you must be careful, use the proper tools, do not lean over it, and be patient. I have seen it springs compressed with improper tools and fail, causing the spring to shoot. This can be dangerous. I had my truck on a lift and the lift had a coil compressor. Make sure to use a coil compressor for this.
Other than compressing the coil, this is a very easy job and I look forward to seeing it done!
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 04-12-2013, 08:52 PM
Ronan's Avatar
Rep:42
Dick Cepek's gun metal 20x9 0 offset 5in backspace. 35x13x20 Terra's (325/60/20)
