Old 04-13-2013, 09:51 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Originally Posted by GSmoggie View Post
VHT Niteshades paint my man. Used it once before and i'm a fan. I mostly like it cause you can wet sand and buff it no problem for an absolute perfect finish. But sometimes, like this time, it looks too good to even touch
it is great stuff!
Thanks
Jeremiah
Discount Auto Performance
Old 04-14-2013, 12:41 AM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Looks good!! Im gettin mine done.
One day....
New audio build in progress
Old 04-14-2013, 08:49 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
Yep, looks great! I love my tinted rear lights. I did the license plate lens too. They were all yellowed and nasty looking. Made a huge difference.
Hey shawnu...it's easy man. What you waiting on?? Get to spraying!
Old 04-14-2013, 08:44 PM
GSmoggie's Avatar
GSmoggie GSmoggie is offline
Vehicle: 2012 Dodge Ram 1500
Rep:35
GSmoggie is on a distinguished road
Thanks guys!
I agree, Shawnu you need to get on the move with the tinting! It's very simple and a big appearance changer.
Old 04-14-2013, 09:23 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Look really good.....Thanks for posting the pics.....
Old 04-15-2013, 08:15 AM
GSmoggie's Avatar
Rep:35
Thank you for the compliment!
I appreciate it when others post pics so I get a good visual...I want to do the same for all ya'll
Old 04-15-2013, 07:50 PM
d33luxx d33luxx is offline
Vehicle: 2013 Dodge Ram 1500
d33luxx is on a distinguished road
nice work man! how many coats did u use and how long did it take you? can you go through the process and what sand paper grit u used
what do you use to take the emblems off too?
Old 04-15-2013, 08:55 PM
Rep:367
I can't answer for the OP but I can tell you what I did on mine. For prep I removed the lights, very lightly wetsanded them with 2000 grit and dish soap, dried them good and then scrubbed them very thoroughly with rubbing alcohol on a clean cloth. Applied three even light to medium coats of Niteshades being sure to get all four edges. Waited five minutes in between each coat best I remember. After Niteshades I waited about 30 minutes and then sprayed four light coats of clear and then a fifth heavier coat. I think I waited ten minutes in between the clear coats. The clear I used said safe to touch in an hour but I left them overnight. I would seriously scrutinize the finish at this point. All of mine turned out slick enough to not really need additional sanding. If you aren't happy with the finish you can very lightly wetsand but I would only do this if you have trash in the finish or are otherwise unhappy with it. I would also attempt to locate some 2500 or 3000 grit sandpaper for wetsanding the finish. I used 2000 grit because the Youtube vid that I watched said to and it was very, very difficult to polish the light sand marks back out by hand. If I had it to do over I would not wetsand after the VHT and clear, however, it is an option if needed. Whether you wetsand the dried finish or you don't, the next step should be a good polish. I used Mother's Ultimate Compound. Reinstall and wax them with whatever finishing wax you use and enjoy!
Here's the thread I done when I did mine.
http://www.ramforumz.com/showthread.php?t=121228
As for debadging, the easiest way I have found is to use fishing line. You may have to double it up to keep it from breaking. Wear gloves so you can hold it and move it in a sawing motion without cutting your hands. On small emblems and whatnot you can peel and roll the adhesive off and then clean it with alcohol or Goo Gone or similar. On larger messes or hard to get off adhesive, a 3M eraser wheel works like magic. Yes, it's $40 but it's worth it and one will last forever. After you get it cleaned up and slick, wax it up good because alcohol and Goo Gone and the like takes the wax off.
Hope this helps!
Old 04-15-2013, 09:01 PM
GSmoggie's Avatar
Rep:35
Hope this helps!
I literally just posted a thread 5 minutes ago about using fishing line to de-badge...weird haha. But yes I agree with Star, Good fishing line will do the job beautifully. Gloves are important and one 3m wheel will last for ALL of your emblems on the truck. I couldn't have explained it better...
Old 04-15-2013, 09:05 PM
Rep:367
Lol, great minds think alike. I didn't even have to buy an eraser wheel. My buddy has one that he let me borrow. I used it a bunch on my truck (to remove the four door trim pieces, the aftermarket 3M installed tailgate cap that went all the way across the tailgate, and the tailgate emblems) and he has used it to debadge his and another friend's Duramax and it still has plenty of life left in it.
I love the look of my clean tailgate with the tinted tails!
Truck was dirty in this pic but you can see what I'm talking about.
