Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 04-12-2013, 11:23 PM
flybeaux's Avatar
flybeaux flybeaux is offline
Vehicle: 2010 Dodge Ram 1500 4x4 Sport
Color: Charcoal
Rep:29
flybeaux is on a distinguished road
Default 08 1500 2wd Lifted
Finally got around to posting my latest mods. Added a 3" front spindle lift and 2" blocks in the rear. I did the entire lift myself and it was pretty easy. I highly suggest having a strong air gun (at least 700 torque lbs). I picked a good one up at Harbor Freight for like $100 (Earth Quake). Anyways pretty easy, just somewhat time consuming. Pleased with the results and was very cheap. $260 for the front spindles and $40 for the block kit. *Note, our axles are much larger around and standard block lift U-bolts will not fit. I lucked out - went to 4-Wheel parts and the guy sold me some used U-bolts for $20!!! Anyways added some Pro Comp 35 x 12.50 Xtreme A/Ts. Now I want to add 3" body lift next. Pics are the day I bought my truck (used) and just after I finished the lift, b/f the tires were added.
Old 04-12-2013, 11:27 PM
05cr125r's Avatar
05cr125r 05cr125r is offline
Vehicle: 2012 Big Horn QC
Trim Level: Big Horn 4x4
Rep:116
truck looks sweet man...and love the color of your truck with the black...nice work
Mods; Line X, Bilsteins set at 2.1, Magnaflow 18", Debadged , Cool White LED Interior, LED license plate, Cool White LED reverse, Fronts tinted 20 %, Stubby Antenna,AVS WindowVisors, Black Honeycomb Grille Insert, Green Performance Air Filter
Old 04-13-2013, 11:34 AM
flybeaux's Avatar
Color: Charcoal
Rep:29
Thanks!
Old 04-14-2013, 12:34 PM
drumwzrd's Avatar
drumwzrd drumwzrd is offline
Vehicle: 2007 Dodge Ram 2wd
drumwzrd is on a distinguished road
Looks great. Do your 35's fit ok or do you have slight rubbing? I just did a 4" spindle lift on my 2007 and need opinions on tire sizes.
Old 06-04-2013, 02:24 PM
flybeaux's Avatar
Color: Charcoal
Rep:29
Only slight rub when I turn fully to the right. I hate the Pro Comp Xtreme A/T I have on. Thinking about a less wide A/T. Although I bought the tires used they have worn down very quickly.
