Old 04-13-2013, 02:33 PM
shaner82's Avatar
shaner82 shaner82 is offline
Vehicle: 2013 Dodge Ram Sport
Rep:47
shaner82 is on a distinguished road
Default I want to lift my truck
Have a 2013 Sport. I would like to give it a slight lift, maybe 4". What do I need to buy in order to do that? Can I still use my stock wheels? Will they rub at all? Will this negatively affect the ride quality? Ride quality is very important to me.
I keep seeing Bilstein 5100 mentioned. Would those allow me to get a few inches of lift without sacrificing ride quality?
What am I looking at spending to get my truck lifted? I don't want the cheapest parts of course, but I do want to keep spending as low as possible, while still getting high quality parts and maintaining the same ride quality I have now (or better if that's possible).
I'm just not sure what all i need to lift my truck. If I have to replace my stock wheels, it's going to be out of the question for now.
Old 04-13-2013, 03:03 PM
Ronan's Avatar
Ronan Ronan is offline
Vehicle: 2013 ram sport crew
Trim Level: Sport crew
Rep:42
Ronan is on a distinguished road
Do the bilsteins up front and call it a day!!! $230 done deal. Mine will be here Tuesday can't wait. Why wouldn't u be able to use your stock wheel. Your not lowering your truck !!
Vararam CAI, Moes 87mm, flowmaster ,20x9 DC gun metals, 325/60/20 Terra's , bilsteins set at 2.1 , access tonneau, raptor W2W nerfs, AVS ventvizors , tints.........
Proud member of LOCAL 361 IRONWORKERS
Old 04-13-2013, 03:22 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
First off, is it a 2wd or 4wd?
If you have a 4wd I recommend a 6" RCX Lift. It is not much more at all than a 4"(Maybe a $100 more).
If you decide you want 4" on a budget you can go Bilstein 5100 Struts and do 2.8" Setting on the struts and then do a 3" body lift. Giving you roughly 4-5" of lift. Another member on here with a 2013 is running a 3" body lift. I personally do not like Body lifts which is why I went all suspension. In the end I knew I wouldnt be happy with a 4". WIth Bilsteins and Body lift plus install you wont be saving a ton of money compared to a 6".
The cheapest route is going just bilstein 5100 struts at 2.8". This will clear 35" tires and is a great leveling kit.
If you have any other questions let me know. Contact Discount Auto Performance for quotes. They are very aggressive on pricing.
SOLD: 2012 Ram 2500 CTD 4x4
Old 04-13-2013, 03:56 PM
shaner82's Avatar
Rep:47
How high can I lift my truck before my stock wheels will just look too small and I'll have to get bigger wheels? Won't 6" be too high for my stock wheels?
If I just get the 5100's, how much of a lift would that get me?
Old 04-13-2013, 04:23 PM
Ram725's Avatar
Rep:347
Well with spacers you can run your wheels.. There was a member on here running a full lift with bilsteins on 35s and stock wheels. Look fairly good. I like wide tires/wheels regardless of lift size.
Bilsteins will get you up to 2.8"
Has 5 or 6 settings (can't remember)
Old 04-14-2013, 03:07 AM
Bilsteins has 5 settings. (0, 0.7, 1.4, 2.1 and 2.75)
Old 04-14-2013, 03:08 AM
Bilstein will probably increase your ride comfort over stock. I know it did for me.
You can run stock wheels s nothing is affected, but it will rid of your rake.
4" lift isn't bad, but your stock wheels will look small
Either way, we can help,you with either
Old 04-14-2013, 10:27 AM
shaner82's Avatar
Rep:47
All I want is a relatively small lift (for now) without negatively affecting ride comfort. If the 5100's can do that for me, I'll buy them, and it seems like everyone recommends contacting you about that.
So if I get the 5100's, I can get a 2.75" lift. I don't know what rake is. I really don't know anything about this stuff and I'm doing as much reading as I can, but there's so much info that it's going to take some time to figure it all out.
So in your opinion, is lifting my truck 2.75" worth it, or should I go a bit higher? I have a lot of home repairs to do this spring so I can't justify a set of new wheels right now. I need to keep my stock wheels, but at the same time, I don't want them to look small or awkward.
If I buy the 5100's, do I need to buy anything else?
Old 04-14-2013, 10:32 AM
shaner82's Avatar
Rep:47
I absolutely love the look of this truck.
http://www.ramforumz.com/showthread.php?t=138581
That is what I want mine to look like. Can I accomplish that while keeping my stock wheels and without having them look too small or awkward?
What would I be looking at spending to get a 4" lift like the one done in those pictures? Is the steering stabilizer required? I'd like to stay under $1,000 for now.
Old 04-14-2013, 12:28 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
to stay under 1000 def inately go bilstiens and maybe body lift rc does a 1 1/4 and performance accessories does a 3 inch no matter what lift kit u buy u will be 12 or 1300 minimum plus in stall and with that hieght u would want new rubber just decide what ur really after cuase when u change ur mind it just gets more expensive hahahaha
have fun enjoy ur new truck
