Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 04-14-2013, 01:39 AM
Billman1 Billman1 is offline
Vehicle: 2012 Ram Laramie Longhorn
Trim Level: Longhorn
Billman1 is on a distinguished road
Default Tow Haul with a Tuner
So what actually happens if I'm running, say a Trinity and canned 93 octane tune. And then push the tow haul button? Does it revert back to a stock tune with the stock tow haul changes of shift points, etc? Or does the tow haul modify the already modified shift points of the 93 octane tune?
Drop-in Amsol;Synthetic;JBA shorties;Dual 18" Mags;180 Tstat;Trinity;WLightning
Old 04-14-2013, 08:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
T/H is a separate function from tuning. It operates the same as it would when using the stock tune. Your shift points will be higher and the 6th gear will be locked out. The 3rd gear will also be used during up shifts.
Note you can't tow a lot of weight with the performance tunes due to the advanced ignition timing.
Sean
Old 04-14-2013, 09:20 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:441
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I run a dyno tune for 93 octane. Mustang Dyno, my guy tweaks my tune a/f ratio and adjust timing to eliminate knock retard under load. A good dyno tuner can optimize your tune to tow with 93 and get no knock.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 230,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-15-2013, 09:11 AM
snrusnak's Avatar
Rep:1385
The OP is using a canned 93 octane performance tune.
Sean
Old 04-30-2013, 10:22 PM
Just to follow up. I bought a White Lightning tune and Dave set one tune up for towing. I'll be testing it in the next week or two. But the performance tunes are awesome. Dave explained a lot about the tunes, the tow/haul mode, etc. So right now just waiting to get that box hooked up.
