Old 04-14-2013, 02:37 PM
Rogue1 Rogue1 is offline
Vehicle: 2010 Dodge Ram 1500 4WD Crew
Rogue1 is on a distinguished road
Default Remote Start Horn Chirp Simple Workaround
2010 1500 ST Crew 4WD 4.7. No Evic.
Dealer installed Mopar remote lock/remote start kit. Apparently there is no way to disable the horn chirp on remote start. I've had two different dealerships go through the menus on their scanners - each of them more than once - and nothing comes up for it. I'm aware that if I had an EVIC it would come up as an option. Still, that leaves me with a chirp on remote start. I don't like it (It's OK if you do, I don't, and it's my pickup). =)
So having doggedly searched this AWESOME forum, I've learned that there are some workarounds for other model years -- snip a wire here, maybe reconnect a wire there -- but none of them apply to my pickup. I've also asked about it a few times, and no one really seems to have a fix, though some have speculated. I appreciate the speculations, but in the end none of them have panned out.
So (the long story), having just installed a WOLO bad-boy air horn (with relay) on my motorcycle, and considering putting one in my truck as well, this morning it struck me. A RELAY. Whether or not I install an aftermarket horn (and relay), I can simply install a relay in the existing horn circuit, trigger it off another circuit that's hot only when the truck is running ... or when the key's on ... or ... actually that part I can figure out later.
I know someone will come along with a reason or reasons not to -- maybe some day I'll want to honk my horn when the engine is not running -- MAYBE we could even conjure a scenario where it would save my life or someone else's. So OK, I'll acknowledge and respect our ability to imagine such a scenario, and then move on. Day in and day out, I would use my remote start a lot if only it would STFU. So I thought I'd share this simple little idea. It kinda made my morning, and someone else might like the idea, too. =)
PS, remember I don't like the chirp, and it's my pickup, and that's all we need to understand about that. =)
Peace,
Rogue
Old 04-15-2013, 11:42 AM
bigtone's Avatar
bigtone bigtone is offline
Vehicle: 2014 Laramie quad cab
Color: Flame red
Rep:22
bigtone is on a distinguished road
Although I own a 2010 Ram, I have alot more experience with Cadillacs. I installed a few aftermarket remote starts on them, and I had 1 Deville that would chirp the horn during a remote start. I tried hitting the door unlock before I remote started and it did not chirp anymore. I believe it was the security system causing this. Worth a try.
Old 04-15-2013, 07:20 PM
BoosTT BoosTT is offline
Vehicle: 2011 Ram 1500 Quad Sport 4x4
Color: Gray
Rep:15
BoosTT is on a distinguished road
My 2011 doesent chirp with OEM remote start.
You could rewire the horn.
Old 04-15-2013, 08:35 PM
BoosTT, please describe 'rewire the horn' in specific detail.
Rogue
Old 04-15-2013, 08:38 PM
Thanks bigtone, I knew it wouldn't work but I gave it a try anyway.
Old 04-15-2013, 08:56 PM
Hemiman345's Avatar
Hemiman345 Hemiman345 is offline
Vehicle: 2010 1500 4x4
Color: Inferno Red
Hemiman345 is on a distinguished road
Check your owners manual. Pre evic had a key cycle or something to disable chirp on lock and unlock.
Old 04-16-2013, 08:27 PM
Color: Gray
Rep:15
Use a relay. Find the horn switch wire and splice that into pins 85 and 86 of the relay. Splice the horn power 12v wire from the fuse box across pins 30 and 87a on the relay.
I really think its a setting somewhere though. Try the ram smartphone app.
Old 04-17-2013, 12:02 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
You may want to give this a shot: For vehicles not equipped with the EVIC, perform the
following procedure:
1. Press the LOCK button on a programmed RKE transmitter
for at least four seconds, but no longer than ten
seconds. Then, press the PANIC button while still holding
the LOCK button.
2. Release both buttons at the same time.
3. Test the feature while outside of the vehicle by pressing
the LOCK button on the RKE transmitter with the
ignition switch in the OFF position and the key removed.
4. Repeat these steps if you want to return this feature to
its previous setting.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 04-21-2013, 01:17 AM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
Could have swore I seen it in the evic menu. Just have the key in the on position, but not running and search through the system settings
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 04-21-2013, 10:03 PM
Hemiman 345, the horn chirp on lock and unlock is already disabled, but thanks.
