Old 04-21-2013, 10:04 PM
Rogue1 Rogue1 is offline
Vehicle: 2010 Dodge Ram 1500 4WD Crew
Rogue1 is on a distinguished road
Originally Posted by TORMENTOR View Post
Could have swore I seen it in the evic menu. Just have the key in the on position, but not running and search through the system settings
Tormentor, I have heard this before but I don't have EVIC. Thanks.
Old 04-21-2013, 10:06 PM
Originally Posted by rdsabin View Post
You may want to give this a shot: For vehicles not equipped with the EVIC, perform the
following procedure:
1. Press the LOCK button on a programmed RKE transmitter
for at least four seconds, but no longer than ten
seconds. Then, press the PANIC button while still holding
the LOCK button.
2. Release both buttons at the same time.
3. Test the feature while outside of the vehicle by pressing
the LOCK button on the RKE transmitter with the
ignition switch in the OFF position and the key removed.
4. Repeat these steps if you want to return this feature to
its previous setting.
rdsabin, I've tried that before but no luck. Thanks.
Old 04-21-2013, 10:10 PM
BoosTT, your description is exactly what I was offering up as a workaround. I guess I got the impression from your comment that you had another idea.
Also, I understand that you would think there is a setting somewhere. That's why I've pursued it. And having pursued it, now I am offering up the relay workaround idea for anyone else who is in the same boat.
Old 04-21-2013, 10:19 PM
So thanks to all for your suggestions, even those that aren't relevant. Seriously, I do appreciate the replies.
I also hope that the workaround I offered up may be of use to someone.
This forum has been invaluable in the year that I've owned my pickup. THANKS!
