Old 04-14-2013, 07:13 PM
Rtsitler Rtsitler is offline
Vehicle: 1999 Dodge Ram
Rtsitler is on a distinguished road
Default Driver power door lock not working
1999 Ram 1500 regular cab
Lock/unlock button makes passenger side operate normally but driver side makes the noise like its working but it doesn't work.
I can operate the lock with the key like normal so I think the bar mechanism is in place and working.
I have an aftermarket RKE/remote start installed and driver side doesn't operate but passenger side does with key fob.
I tend to think its the actuator gone bad.
Looking for more schooled opinions on this matter.
Thanks in advance for our help.
Richie
Old 05-13-2013, 10:59 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Yes, it's your actuator. If you have power to the actuator, but nothing is happening... Try swapping actuators, passenger to driver, and see if the issue follows the actuator. If not, then you've got a stuck rod.
Old 02-01-2015, 11:04 PM
Steve D Steve D is offline
Vehicle: 1999
Trim Level: Quad Cab
Color: Red/Silver
Steve D is on a distinguished road
I've been having a somewhat the same problem. I have electric locks; the driver's side works fine but when the door lock button is pushed on the arm rest control, the passenger side just has a constant motor sound and the lock doesn't move. Is this a problem with the lock motor?
Old 02-01-2015, 11:07 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
sounds like your locking linkage is stuck
Old 02-14-2015, 03:03 PM
Vehicle: 1999
Color: Red/Silver
Took off the door panel and lubricated the linkage. It seemed to help a little, but it makes me wonder if some of the teeth in the motor/gear have been stripped. I'll have to take it apart and check.
Old 03-08-2015, 11:15 PM
Vehicle: 1999
Color: Red/Silver
Update: had to replace the door lock actuator and now it works fine. I haven't taken the old one apart but I'm guessing some of the teeth on the gears have gone away.
Old 03-14-2015, 11:27 AM
Color: Blue
Rep:95
glad you got it figured out
