Old 04-16-2013, 02:37 PM
RAMMED84 RAMMED84 is offline
Vehicle: 2004 dodge ram
Trim Level: Slt
RAMMED84 is on a distinguished road
Originally Posted by Grumpy View Post
Rhino won't cover normal wear and tear and they certainly won't cover fading under warranty.
Go get LINE-X ReNew which is a patented process available for any brand of bedliner. After ReNew, your bedliner will look brand-spanking new and will have a top layer of LINE-X Premium which won't fade like your Rhino.
Sheesh, that sounds like a commercial!
The line x will still only be as strong as the rhino lining it is sprayed on top of I would assume. If the rhino liner is not holding up, the line x will still be on a crappy foundation so to speak.
Old 04-16-2013, 03:01 PM
Grumpy Grumpy is offline
Rep:13
Grumpy is on a distinguished road
That old Rhino is called Tuff Stuff. It's a very weak product and Rhino doesn't even advertise it anymore although dealers still spray it.
LINE-X is WAY stronger than Tuff Stuff. I even have the technical data sheets of both products if you want to compare numbers.
Old 04-16-2013, 04:04 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If they will honor the warranty(they should) then they will grind/sand out the bad areas and re spray them. You will just have a very minor line where the seams are. If you go to linex and get the renew it will look brand new and be better than the original rhino liner.
I don't know how people tear up these liners. We use the hell out of our beds and our regular linex liners look like new. No a single dent or tear or peel anywhere. And I'm not just talking about 2x4's and mulch, I slide pallets of brick, etc weighing 1,000+ lbs in my bed often and no damage. I mean I'm pretty careful when loading and unloading, but to me that's just common sense. Use a little caution and it'll last forever. Mine's out in the sun 24/7 too, but I use the cleaner/protectant on it once or twice a year and it looks pretty good.
Sean
Old 04-16-2013, 04:30 PM
Hermes1's Avatar
Hermes1 Hermes1 is offline
Vehicle: 2012 Ram 1500 Sport
Color: Flame red
Rep:2554
If you like the sprayed in bed liner and it works well for you, why not go back to Rhino liner, show them what happened and ask what they will do about it? Bedrug makes a nice product, I like mine but depending how you use the bed of your truck it may or may not be the best choice.
Best, Bruce
Sure you can take my truck, the keys are under my Akita.
Old 04-16-2013, 04:56 PM
Rep:13
LINE-X has a new one coming out in July called Platinum. It's like Premium (doesn't fade), but it's 300% tougher. I don't have the technical specs on that one yet though.
Old 04-16-2013, 08:50 PM
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:54
The Crow 1994 will become famous soon enough
LINE-X Platinum, available about July 2013. Extreme duty with UV protection. Platinum is 300% "tougher" than Premium. Absolutely the toughest bedliner offered on the market, hands down.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
