Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 04-15-2013, 08:15 AM
Gears49 Gears49 is offline
Vehicle: '11 Dodge Ram 3500 4WD
Gears49 is on a distinguished road
Default Dead Pedal
I'm experiencing a dead throttle after cruising for a couple of minutes at around 50mph. I'll try to accelerate and nothing happens. If I push the pedal to the floor, the trans will kick down and I'll accelerate. Also, when I experience the dead pedal, if I let up and then push the pedal, it will accelerate. I'm experiencing no codes but I think the apps (TPS) may be the culprit. Any suggestions?
Old 08-13-2013, 05:58 PM
Joeinblue Joeinblue is offline
Vehicle: 1994 Ram 1500
Rep:15
Joeinblue is on a distinguished road
You need to check for codes by cycling the ignition switch on and off three times. It sounds like your injector pump (VP44) is failing. I had this happen with our '01 5 speed truck. Dead pedal is usually the first sign. When you get your code or codes in the odometer window, google search them.
-Joe
Old 08-14-2014, 06:18 PM
Outdoorsman14's Avatar
Outdoorsman14 Outdoorsman14 is offline
Vehicle: 2014 Ram 1500 Outdoorsman
Trim Level: Outdoorsman
Outdoorsman14 is on a distinguished road
Anyone have a dead pedal on their 2014? Im not expecting great response like my mustang but on the initial push (up to 1/2 to 1 inch of depression) nothing happens..? The ford fusion rental car I drove last week was better than my truck.. any ideas/help? Cant find a thread about it. Thanks!
Old 09-14-2014, 09:22 AM
bsoren bsoren is offline
Vehicle: 2014 Ram
Color: Maximum Steel and silver
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
bsoren is on a distinguished road
My 2014 Ram 3500 is terrible with a dead pedal issue. I take off to make left turns and have to make sure I have a lot of room. Almost been hit a couple times and I started out with plenty of room to make the turn. Getting very frustrated. Any suggestions? Hoping they come out with some software upgrades. Personally I think they may have given all that torque and power but maybe did not engineer the mechanicals to be able to handle it so have to feed it to you slowly. Trying to trade to a Ford. I need power and am all Mopar but this is getting frustrating.
Old 01-15-2015, 12:55 PM
anexxe anexxe is offline
Vehicle: 2002 dodge ram 3500
Trim Level: tampa
Color: blue
anexxe is on a distinguished road
I had problems with dead pedal. Replace the TPS and had to replace the ECM also. $2,000 later its all good.
Check your codes and you'll get the info you need
Old 02-01-2015, 09:31 AM
Vehicle: 2014 Ram
I was in Saltillo Mexico the past couple weeks on business and was able to speak with guys from the assembly plant there about my dead pedal issue on my 2014 diesel. I was told they do have an issue and are working on it. I was told a new flash will be available in 6 or 7 months but a fix is coming so I guess I will be patient. I will update here when I hear from the engineers. I have exchanged emails and was told they will keep me up to date. I am glad I was finally able to get an acknowledgement that there was an issue and they are working on it.
