Old 08-06-2014, 05:07 PM
markyone markyone is offline
Vehicle: 2001 Dodge Ram 2500 4X4
Trim Level: Laramie SLT
Color: Maroon
markyone is on a distinguished road
Default 2001 Cummins diesel won't start.
Problem started about 6 weeks ago. Went to start it and it just clicked. Tried again and it started. Since then sometimes it starts right up but other times it will only click one to thirty tries and then starts. Now it will just click - won't start. Tried a lot of times. 12.1 volts on one battery 12.2 on the other.
Old 08-06-2014, 05:35 PM
dodge man's Avatar
dodge man dodge man is offline
Vehicle: 2004 Quad Cab diesel
Rep:221
dodge man has a spectacular aura aboutdodge man has a spectacular aura aboutdodge man has a spectacular aura about
I know people think a 12 volt battery should have 12 volts but normal is more like 13 volts. I'd say you have dead batteries. Try jumping it and see if it starts. If it does you probably need new batteries. Its best to replace both at the same time.
2004 3/4 ton Quad Cab, 24 valve 5.9 Cummins
Old 08-06-2014, 06:38 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I'd also try tapping on the starter while someone spins the key.
The diminishing problem of it clicking sounds to me like the starter is bad. It could be the solenoid or bad continuity between the solenoid and the starter.
Old 08-06-2014, 06:47 PM
RayK RayK is offline
Rep:72
RayK will become famous soon enough
And obviously make sure no corrosion is on the battery terminals.
Old 08-09-2014, 08:43 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I agree with Warlock. Sounds like the contacts in the starter or the solenoid.
Old 01-15-2015, 01:57 PM
anexxe anexxe is offline
Vehicle: 2002 dodge ram 3500
Trim Level: tampa
Color: blue
anexxe is on a distinguished road
Sounds just like the starter needs replaced. $150 and about 30 minutes to do the job
