Old 04-16-2013, 01:03 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
Originally Posted by Iqudayo View Post
(***reserved for future posts***)
careful, that "reserve" spot only lasts for 24 hours. then you won't be able to edit it anymore.
Old 04-16-2013, 01:09 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Old 04-16-2013, 01:12 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Cheap Canadian Labour
Rep:1821
As stated you can only edit your posts within the first 24 hours. During a build thread all posts and pictures just follow the flow of the thread and people will have to go through to see your newer mods. But once someone has already visited your thread they can hit the button that brings them to the newest unread post for them so they aren't always going through the entire thread to find out where they left off.
Old 04-17-2013, 01:35 AM
Rep:1804
I like everything so far
Old 04-17-2013, 07:37 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Very nice, love the look
Old 04-22-2013, 09:53 AM
Iqudayo's Avatar
Rep:563
Ok so this weekend I got the oil changed, and changed the air filter it was dirty.... in the process I did as I was recommended by Slingshot383 I removed the silencer in the air box but I did not get to open the hole at the bottom. I did notice a gain in fuel of 2 miles that was probably also due to changing the air filter but I can hear the turbo a little more. I took a 2 hour ride to Cabelas in Pa. and 2 hours back nice ride
1. Remove the air filter, remove the silencer in the tube right before the turbo and re install everything it was a 10 min mod.
2. Next weekend will be part 2 cutting the 4" hole in the bottom and running the tube to the bumper
Thanks Slingshot383 you the man !!!!!
Old 05-22-2013, 09:55 AM
Iqudayo's Avatar
Rep:563
I finally got my build sheet:
Vehicle Description: DODGE RAM SLT 4X4 2500 CREW CAB PICKUP
Model Year: 2010
Body Model: DJ 7 H 91
Sales Code Description
M9 Cloth 40/20/40 Prem Bench Seat
V3 Dark Slate/Medium Graystone
ADAP Luxury Group
AFZ Big Horn Regional Package
APAS Monotone Paint
BABS 160 Amp Alternator
BCNS 730 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CBZS Prem Vinyl Door Trim w/Map Pocket
CB9S 2nd Row In Floor Storage Bins
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKES Floor Covering Carpet
CLES Front & Rear Floor Mats
CSPS Driver/Passenger Assist Handles
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CVHP Front Center Seat Cushion Storage
CV1S Chrome Accent Shift Knob
CV2P O/Head Console w/UGDO
DBAC All Automatic Transmissions
DG7 6-Spd Automatic 68RFE Transmission
DH3S Elec Shift-on-the-Fly Transfer Case
DJBS 5,500# Front Axle
DMES 3.73 Rear Axle Ratio
DRQP 11.50 Rear Axle
DSAP Anti-Spin Differential Rear Axle
DS7S Conventional Differential Frt Axle
ETJ 6.7L I6 Cummins Turbo Diesel Engine
GACS Tinted Glass Windows
GFES Rear Power Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GNZP Auto Dim Exterior Mirrors
GUKP Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JATS Instrument Cluster w/Display Screen
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JFJS Temperature & Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKVP 115V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPWP Power Lumbar Adjust
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRTP Power 10-Way Driver Seat
LAZS Vehicle Information Center
LBCP Glove Box Lamp
LDAP Underhood Lamp
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LETS Traveler/Mini Trip Computer
LE4P Black Exterior Mirrors
LHEP Rear Dome w/On/Off Switch Lamp
LMEP Halogen Quad Headlamps
LMGS Automatic Headlamps
LNC Clearance Lamps
LNJP Fog Lamps
LPES Cargo and CHMSL Lamp
MBFS Bright Rear Bumper
MCMS Body Color Headlamp Filler Panel
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MENS Front Wheel Spats
MF1P Bright/Bright Grille
MGAS Ram's Head Badge
MNES Body Color/Chrome Door Handles
MPGP Cummins Turbo Diesel Badge
MPLS Black-Out Tape
MPPP Rear Wheel Spats
MS4S Ram 2500 Badge
MUSS 4X4 Badge
MXBS Front Air Dam
MYFP Bighorn Badge
NAS 50 State Emissions
NENP Diesel Exhaust Brake
NFUS 34 Gallon Fuel Tank
NHBP Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCS Heavy Duty Engine Cooling
NZCP Current Generation Eng Controller
PDM Mineral Gray Met. Clear Coat
QDMS Mineral Gray Met. Clear Coat
RAAC All Radio Equipped Vehicles
RCGS 6 Speakers
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
RESS Uconnect 130 AM/FM/CD/MP3
RSCS SIRIUS Satellite Radio
RSUP Audio Jack Input for Mobile Devices
SBES Power Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SUAS Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TT3S LT265/70R17E BSW All Season Tires
TZHP Michelin Brand Tires
WBGP 17X8.0 Polished Forged Alum Wheels
WF1S 17" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
XA8S Non Adjustable Pedals
XBNP Tip Start
XBSS Pickup Box
XCMP Vendor Painted Cargo Box
XEAP Tow Hooks
XFHS Class IV Receiver Hitch
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGDP Universal Garage Door Opener
XGMS Tire Pressure Monitoring Display
XHCP Trailer Brake Control
XJJP Locking Tailgate
XJ8S Body Color Fuel Filler Door
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X9AP For More Info, Call 888-539-7474
X9BP 1-Year SiriusXM Radio Service
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email.
Old 05-22-2013, 10:36 AM
Rep:1804
SWEET!
Cant wait to see the truck
Old 05-22-2013, 12:50 PM
Iqudayo's Avatar
Rep:563
SWEET!
Now, Now you've seen it.
sending you an email about the shocks now
Old 05-22-2013, 01:04 PM
Rep:1804
Sounds good! Ill respond when I see it
