110v or 12v power in tailgate - enough to cut through plywood/2x4 or heat a can of beans. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 04-16-2013, 07:55 AM
cyberpine cyberpine is offline
Vehicle: 2012 Ram Hemi regular cab
Rep:53
cyberpine will become famous soon enough
Default 110v or 12v power in tailgate - enough to cut through plywood/2x4 or heat a can of beans.
2012 Ram Hemi 4x2. Standard stock trailer connectors in the back.
Whats the safest and best way to get 110v ~1000 watts power plug in the back. I hear the RAM hemi comes with a pretty good alternator.I think using the trailor connector would be a bad idea as cables look real thin and breakers are likely too low.
I figure I need to run some good cables straight to the battery and then an DC to AC invertor to the back in my box.
Or maybe I should stay with 12 volt, but not that many great 12v plug in tools out there.
I just want to be able to cut plywood & 2x4s or heat a sandwich & some beans.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 04-16-2013, 08:59 AM
battlerattle's Avatar
Vehicle: 2016 Ram 2500 Laramie LongHorn
Trim Level: Laramie LongHorn
Color: Granite
Rep:286
Run it to the bed as 12v then plug your converter in when necassary, best of both worlds. Just make sure you use the correct guage wire to handle the load.
Just Got it, Give me time!
Old 04-16-2013, 09:23 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^I agree, do this and you won't ever have to worry about it.
Sean
Old 04-16-2013, 12:48 PM
Todd157k's Avatar
Todd157k Todd157k is offline
Vehicle: 2012 Dodge Ram
Trim Level: Laramie Longhorn 4x4
Color: Deep Cherry Red Crystal
Rep:15
Todd157k is on a distinguished road
the 12v back is best, but is that 1000w inverter going to run a saw? I doubt it. Startup on a motor device is 1.5-2 times the running current. I think you're looking at 2000w continuous inverter at a minimum.
Having said that, 2kw @ 110v is 18 amps. You're not only going to need some 8 awg wire (min) but you'll need to keep the truck running when running it, or face a dead battery in about an hour.
I spend most of my money on cars, motorcycles, and boats. The rest of it I waste.
Old 04-16-2013, 01:27 PM
ShawnC13's Avatar
ShawnC13 ShawnC13 is offline
Rep:2055
ShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond reputeShawnC13 has a reputation beyond repute
A 1000W inverter will not run a saw as stated the initial draw on startup of the saw will be way over that.
Edited: Deleted wrong information, Sorry I was working with AC 120V not from the DC power source
Old 04-16-2013, 04:47 PM
grizzlylongcut grizzlylongcut is offline
Vehicle: 2011 ram sport
grizzlylongcut is on a distinguished road
i just use a this,http://www.wisesales.com/eu2000ia-ho...g#.UW24J8o33qU
ive also got a good set of cordless tools,mostly makita,or rigid. the 18v lithium will get most stuff done for ya
Old 04-16-2013, 04:52 PM
ShawnC13's Avatar
Rep:2055
Have to say you can't go wrong with a honda suitcase generator they are a great little setup.
Old 04-16-2013, 05:11 PM
Todd157k's Avatar
Rep:15
um... you forgot about the wire length to the battery in the front.
Old 04-16-2013, 05:47 PM
ShawnC13's Avatar
Rep:2055
Thanks I edited my post as I was working with 120V AC. Posted without even thinking of it being 12V DC.
